So to begin I am not responsible if you mess up the front off your car
Tools needed:
chisel
spot weld remover drill bit
a big hammer
drill
some gloves
First you need to rmove fenders and front bumper headlights and horn. There should be a DIY on here some where for it.
Now take your spot weld remover drill bit and and drill out all the spot welds you don't wanna go all the way through. That way you leave something to weld on to later. I will count the number off spot welds tomorrow for a exact number. Were I have circled is were you wanna drill at. You will see the dimples
Now you want to start from the top and go down. So take your chisle and knock up the lip on the corner up under the fender thats were you wanna start to get it off. Were the red arrows are is were you wanna knock up.
Then keep working your way down and you will catch on
Will update when I have it weled on
Tools needed:
chisel
a big hammer
drill
some gloves
