EXT: Greasing a lock
    MRT
    sneaky motherfucker
    hmmm my trunk lock isnt frozen but i cant seem to get it opened how do you get yours open with un frozen locks?
    http://www.cb7tuner.com/vbb/showthread.php?t=189897 MRT
    http://www.cb7tuner.com/vbb/showthre...09#post3003309 EF hatch build
      just did this a couple days ago, lol opening through the passenger door was getting too ghetto...how would you grease the rear passenger door lock on a sedan, when you open that door for me the handle stays in the open position and the door wont close unless its its manually pushed into close position from the outside
      IG:worldboss_sanjcb7
        Are you saying your lock is frozen? I tried the lock unfreezer stuff. Didn't actually do much. I just waited for it to thaw by itself, then used this stuff.
        You could try the lever in the cabin, and make sure it isn't locked.
        Other then that, take apart the assembly in the trunk and grease that.
        That's exactly what I was doing. Everytime it would get could my drivers side would freeze.
        As for your question, I'm not sure. There isn't a key hole there. Try just taking out the handle and greasing all the moveable parts.
        MRT
        sneaky motherfucker
          I'm pretty sure he's saying his locks aren't frozen, but they still won't open.
          Click picture to see my mrt
          Instagram: sikz6
            I was thinking of two kinds of frozen:
            Water + cold = Ice
            OR
            Age + water = Rust
            I thought he meant rust and I was asking about water.
            I was kinda distracted while writing that
            MRT
            sneaky motherfucker
              i was hinting you should make a diy on opening your trunk like the hood opening diy just for kicks my trunk is fine bro lol
