I am going to be getting Sparco NS2's soon and they are 16s which i know should fit my 1991 Accord Ex fine. But will the tires fit. The stock size for 91 CB7 Ex accords are 195/60r15, but the tires on the sparks are 225 65 R16. Will these still fit? and clear my calipers and be alright and safe to drive with. I just want to know. THANKS!
Will these fit?
^^ We need to know what offset they are too, as that can make a huge difference. Also whats the width of the rims?
205/50/16's I believe would be the best choice, depending upon the width of the rim.
Right now with 225/65/16's the sidewall height is too much, thats the equivalent of 22" rim/tire combination. Our cars use 21", so it would mess up your speedometer bad.
I don't know whats worn with the speedometer. An i don't know how to fix it. So yeah. I have had people tell me its all types of things of what it might be. Okay, how about this.
Will these tires, fit on my car and will i be able to drive safely until i can get new tires that will be proper (a few months) ?
They will work on your car. That's about all anyone will tell you. Nobody wants the responsibility of telling you it's safe to use the wrong size tires on your car.
If you're not in desperate need of new tires right now, and you just want the wheels... i suggest buying the wheels and selling those tires on ebay or craigslist. Then buy new tires of a proper size.
As for the speedo, it's pretty simple... either your VSS is bad, or your speedometer itself is bad.
I don't understand why you're so anxious to modify your car when such an important part isn't functioning...
205/40/16 would look absurd on your car. I made that mistake when ordering wheels for my friend, and his CD5 looked like a HotWheels car.
Get tires of the correct size for the wheels. I would say don't go any wider than 215. 50 should be the smallest aspect ratio, 55 should be the tallest. More than that, and you'll have problems. Less than that, it'll look dumb... and it won't protect the wheel very well.
I feel like this guy keeps asking Google-able questions...'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
Don't go below 195.
Since we don't know the actual width of your rims, it's impossible to say. If they're stupid wide, you may HAVE to go with a 215.
The size cloudasc suggested is good. 205/50/16. If you want a fatter tire (and more protection for the wheel) go with a 205/55/16.
Originally posted by domesticated View PostI feel like this guy keeps asking Google-able questions...
