Transmission Issues Help!!!
    ok i have an 93 accord coupe a/t 194,xxx it has always shifted a lilttle hard so i payed it no mind but today i got all the way up to 50mph and it didnt change gears & my rpms went crazy high so i put it in park to try again then my d4 light stayed green it has never done that.....i tired again hours later now its fine
    what should i do? sell it?
    have you ever changed the tranny fluid?
      yea i did at like 185,xxx full flush though i heard it may not hard been a good choice....but i drive this car REALLY hard its takin a beating but its been good just tryna see what the d4 light staying on has to do with anything i thought that was a sign on it about to go on you
        theres a blue plug behind the passenger kick panel, short it with a wire or paperclip,
        then turn the key to just before it starts, the CEL and transmission indicator on the dash will blink you codes, like morse code. then you can decypher those codes. The number of long flashes indicates the number in the 10s column. The number of short flashes indicates the number in the 1s column. For example, 4 long flashes followed by 3 short flashes would indicate DTC 43. Your TCM might be going out which you can fix if you can wield a soldering iron.
        http://homeandauto.ldsdates.com/2010...-honda-accord/
        I cant find the list of codes, it should be in a repair manual
          most of your car problems are answered here:
          http://www.cb7tuner.com/vbb/showthread.php?t=158531
          And for your D4 light, follow this tutorial:
          http://www.cb7tuner.com/vbb/showthread.php?t=21259
          PS, with an automatic, dont try to shift it like its a manual, and dont launch it by revving in neutral and dropping it into gear.
          You will just burn out the torque converter.
          MRT
            he said sell it. what kinda accord owner are you! j/k
              Where's Cloudsac? He should be here shortly. Lol.
