I have a F22A6 IAB/Butterfly and black box sitting on my bench. Trying to test it before I put it in my car.
If I apply suction to the diaphragm the butterflies close. That's good, right?
If I apply suction to the end of the #12 tube where it attached to the IM, I get a vacuum that holds. So that's good, right?
If I apply 12v to the electrical connection the vacuum is released from the black box. So that's good, right?
Here's the part that's confusing me.
If I apply suction at the #12 tube as above, shouldn't that suction travel into the black box, create a vacuum there that also creates suction at the diaphragm and holds the butterflies closed?
It doesn't do that so I'm wondering what creates the suction to keep the butterflies closed.
I'm thinking that the solenoid should be allowing that IM suction to pass through it to the diaphragm and it's not. Is that correct?
