Old 09-30-2012, 11:08 PM   #1
lucifer1
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
EXT:Shaved Hood Squirters
By no means am I an experienced body man. Keep in mind this may not be the best or fastest way to do this but it worked for me.
Required tools/supplies
Welder
Copper tube
Air Compressor
Right angle grinder with 80 grit
Sanding block with 80 and 320 grit
Hood Stand
Ratchet with 10mm socket
Body filler
Primer
paint gun
Since the holes are still fairly small, I decided to just build up weld on top of weld to fill the holes. I think it is better to drill out the holes with a step bit and make round filler pieces to weld in but I wasn't that motivated.
First take off the hood and place on stand
Grind off the paint around the squirters
Place copper under the hole to weld against as well take some heat away. We used a copper tube flattened on one end.
Slowly tack weld the hole intermittently blowing air across to keep it cool. Do not overheat the metal or it will warp.
Grind the weld smooth then check the weld for pinholes and unfused areas. Do not overheat the metal when grinding. Reweld as needed.
Grind smooth again and sand out the area in preparation for body filler
Apply body filler. I used Rage Gold
Sand smooth with 80 grit
Primer the hood. I used FeatherFill G2. No more holes
lucifer1 is offline   Reply With Quote
Old 09-30-2012, 11:18 PM   #2
Raf99
Cool! What inspired you to do this? Were you thinking of deleting your windshield washer squirts/pump/tank or moving them to the wiper arm?
Raf99 is online now   Reply With Quote
Old 10-01-2012, 12:19 AM   #3
mercyboy
mercyboy is cool... so far.
nice write up.....but is it going to be dangerous just incase or your prepared to come out and spray the car windshield with windex
VS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
mercyboy is offline   Reply With Quote
Old 10-01-2012, 12:50 AM   #4
Quashish
Quashish seems to have made some friends!
its not dangerous if you keep a clean car
C-3PO's MRT USDM yo!
Quashish is offline   Reply With Quote
Old 10-02-2012, 11:31 AM   #5
Darkcloud
Darkcloud is cool... so far.
In california we dont ever have to use the squirters
Good right up
Darkcloud is offline   Reply With Quote
Old 10-02-2012, 08:42 PM   #6
F20A CB7
I use glass cleaner foam, to me works better
Op coolio diy. I did this to my coupe with tape lol.
