I debated where to put this because it was easy but was more of a how to
I didn't like my Parking lights flash every time I unlocked and locked my car
so while this may be short it's a option I thinks cool
Material's
Wire
wire stripper's
flat head screw driver for taking out the hazard switch
Alarm installed
I started by un plugging my negative battery terminal and then went to
add wire to my alarm Flash/blinker.etc with a butt end connector to
my hazzard switch and found that it controls a lot
so I took my volt meter (when the battery was still connected) and saw 2 wires that it sends voltage to to light up all 6 lights
(there it show's one wire out it goes just under that second row in) those run the blinker lights with 12 volts connected. if you try running both together it will act like you have your hazzards on when you use your blinker's so grab your Diodes and connect on to each and twist them together at the top so you don't get feed back from one another. Restore power and enjoy your amber/white.etc like a late model car as you unlock or lock with your clicker.
here is me locking and unlocking
Material's
Wire
wire stripper's
Alarm installed
