Well as we all know the rear defrost and fog light switch have a back light and indicator light.
The back light is known as the t3 tec bulb. These bulbs are almost always burned out! I took 16 of the bulbs from a junk yard couple months back and not one of them worked.
cp[mike] did a DIY on LED conversion on these, however he used a 3mm LED and different value resistor. So I took it upon myself to update and try something different, since I love to have all my lights work.
I did both my defrost and front foglight button/switch
Defrost I put in an Orange LED for the backlight. The indicator is already orange from factory, so it will match
Front foglight I put a Green LED for the backlight. The indicator is green from factory, so this will match too.
Pictures for reference
TOOLS NEEDED
Small flat head screw driver
Soldering Iron
Solder (I used radio shack 60/40 rosin core .032" diameter)
Wire cutter/stripper
Multimeter
Helping Hands
Lighter (for heat shrink)
PARTS NEEDED
5mm LED <---- Your desired color (I bought mine from www.superbrightleds.com )
1000 ohm aka 1-kohm 1/4 watt resistor Color band is Brown Black Red Gold (part # from Radio Shack 2711321 its a 5 pack
very short piece of stranded wire I believe I used 16 gauge
very short piece of heat shrink tubing size 1/16"
Which ever switch/button you desire to add.
This DIY also can work with anything that requires the small t3 tec bulb. ie rear defrost, front foglight, rear foglight and bumper pole etc...
First thing is to remove the switches/buttons
Grab your short flat head screwdriver and go inside your car.
Grab the flat head and insert it in the bottom slot of the button and pop the button by grabbing it and pulling it out.
Then push in the release of the plug on the back of the switch
Here is my working table with the parts and tools listed above
With the same small flat head remove the indicator bulb on the bottom of the button. Turn counter clockwise and slowly pry out the bulb if it gets stuck.
Then turn the button and you will see the t3 tec bulb on the side. Remove the bulb.
Then I scratched out the positive + and the negative - on where the leads are for the new LED.
Now you have to remove the casing of the button/switch pry with possibly 2 small thin flat head drivers and pop out the button from the rear.
TOOLS NEEDED
Soldering Iron
Multimeter
Helping Hands
PARTS NEEDED
