ENG: Changing a thermostat VIDEO
    Had to remove it in an emergency the other day.
    Thought I'd make a video showing how to put it back together.
    For reason it's always been a daunting task for me, up until I had to do it.
    Now you can learn too!
    MRT
    sneaky motherfucker
    I did this last week. I needed to replace my hoses so i decided why not doing the t-stat too. Man coolant was like $12
    10th Anniversary Accord.
    05 Audi A4 Ultra Sport 6MT.
      I had all relatively new coolant in there. I guess I just didn't bleed it properly when I did the
      motor mount. I overheated a lot, and had to put pure water in.
      So, now not only am I not completely 50/50, but I had to add in new Antifreeze and non distilled water.
      I think the water is alright. It was Reverse Osmosis water. But still not as pure as distilled.
      Pure Antifreeze up here was like $14 dollars.
      MRT
      sneaky motherfucker
        ^ . I will start doing it your way since I'm tired of getting burned by the coolant becuase i bleed the system with the engine running.
          I can't watch the video right now to be sure, but this is the one time I let the engine run.
          I got bored of waiting for the fans to come one, but I left the funnel in the spot for the radiator cap and let it run for about 5 minutes. That way I knew I had as much in there as it would fit.
          MRT
          sneaky motherfucker
