On this swap I unbolted the 4 14 mm bolts on the left side of the Accord seats, the 2 14 mm bolts on the right side of the sear as well as the 12 mm bolt. For the prelude bolts its 2 12 mm bolts on the seat pan and 2 14 mm bolts onthe back for the left side, the right side is 3 12 mm bolts.
As long as your careful the Prelude seat unzips and pulls apart nicely, you only have too stretch the Accord seat slightly too get too the upper bolts.
All I needed for tools for this job were a 3/8 ratchet, short extension, 14 mm socket, 12 mm socket, a Phillips, a couple of flat heads and a drill. The bottom of the Prelude seat simply bolted too the Accord rails with the 12 mm prelude bolts and plastic washers. The right side of the back also bolted up with the Accord bolts and washers. The left side required measuring and drilling then bolting up with the 14 mm bolts. If you've never drilled metal make sure too start with a smaller bit and step your way up. Do not try too just drill through with your final size it will only burn your bits out. There's only one place too make a mistake and that is when its time too measure double check your double check.
After reassemble all four original bolt holes still line up. Start with the right rear bolt then go too front left bolt then right front bolt. finish with the left rear bolt. this takes a 14 mm socket 3/8 ratchet and small extension. (trim was not reassembled too make it easier too take pictures)
