Pics will be up soon.
This is what you will need:
- Pencil
- Paper
- Degree Wheel (The bigger the more accurate the readings)
- Pointer (can be made from a coat hanger)
- Piston Stop (Get the kind that goes in the spark plug hole)
- Dial Indicator (You can use one or more than one)
- 19mm Socket
- Ratchet or Breaker Bar for Socket
- Adjustable Cam Gears
How to do it:
The process of camshaft degreeing almost always starts with the adjustable cam gears set at the zero position and the camshafts installed to match factory specifications. I also recommend that you degree the cam with
the lash set at 0.000.”
1. Install the Degree wheel onto the crankshaft. Try to get it as centered as possible. Don't worry if you can't get it perfect, as you will be moving it later.
2. Fashion a rigid pointer from stiff wire or an old coat hanger and attach it to the engine block. This pointer locates the degrees on the degree wheel.
3. Rotate the crank to get the # 1 piston at TDC and check to ensure that the valves are fully closed then adjust the pointer to zero (0º TDC) on the degree wheel.
4. Turn the crankshaft opposite the running rotation (clockwise) approximately 15-20 degrees. Install a piston stop into the # 1 spark plug hole. Note: A dial gauge can also be used.
5. Continue to turn the engine in the same direction (clockwise) until the piston comes back up and just touches the piston stop. Make a note of the exact number on the degree wheel that the pointer is on.
- Pencil
- Paper
- 19mm Socket
How to do it:
