Hey y'all! New to the community
    Name's Jevon, I'm from Georgia and go to college in Michigan, way up in the Keweenaw. My '90 lx was left sitting in the Georgia sun for about 7 years by a family friend not driven and neglected with clutch and brake issues (lost track of how many wasps nests we found in the thing, there was even one in the tail pipe), but worst of all, the previous owner painted it with a PAINTBRUSH!!
    While on break from college last May I went home and went to work on it with my dad. Got the clutch, breaks, and gas tank done while there but didn't finish by the time I had to travel back to Michigan in June for work and school, so he finished it up himself and drove it to Michigan for me in December. Unfortunately, one of the cylinders died on his drive up here which we attribute to failure to replace the old spark plugs and wires.
    Car's been running on three cylinders and burning oil ever since but I drove it very little this past semester. Never got to drive it while fully functional
    Here's the list of parts replaced to get it back up and running:
    Clutch master cylinder
    Clutch slave cylinder
    ^(These two took the longest, we really struggled with bleeding the clutch to remove all air out of the system.)
    Brake master cylinder
    Front brake pads
    Front brake rotors
    Repaired broken wheel stud on passenger side.
    Radiator
    Battery
    Timing Belt
    Serpentine belt
    Gas tank (old one had a hole in it, PITA to replace!)
    Fuel pump
    Tires
    Windshield (old one cracked)
    Snow tires (My school, Michigan Tech, was the #1 snowiest school in the country this year)
    Front bumer (damaged)
    Rear bumper (damaged)
    Driver's side mirror
    Radio
    I believe that's it, I'm sure there's something I'm forgetting.
    I'm in the process of having an H22 swap done. http://www.cb7tuner.com/vbb/showthread.php?t=206654
    In the beginning:
    Paint job done right in the works (big time props to my dad):
    The car when delivered:
    New windshield from safelite
    The car today:
    Welcome to the forum!! she is looking sweet with that new paint job!! keep up the good work and pics coming!!
      Thanks! Will do.
        Sweet ride!
          very nice with the fresh paint love the color
            Originally posted by preludeNinja View Post
            Sweet ride!
            Thanks!
              Appreciate it, me too
                Wow. Thanks Dad! Paint looks good.
                Form.Follows.Function
                  welcome.
                  For the love of god, STOP putting H.I.D's in stock housings!!! Projectors ONLY!!!
                    My attempt at patching up my f up.
                    While replacing my air conditioning (front window regulator and motor), I torqued the left window bolt too much which in time ripped the nut out of the plastic housing on the window causing the window to go limp (I hate plastic).
                    So instead of buying a new window I decided to go the band-aid route using some JB weld and an old clamp I made in class few years ago but never use.
                    I let the clamp sit on it over night and revisited it in the AM
                    Putting JB weld up to the ultimate test!
                    Made sure I didn't eat ANY Wheaties prior to re-installation.
                    If I never mention this ever again then JB Weld passes the test!
                      Nice job with the jb weld, and welcome to the forum. There is alot of good info here and good luck with the swap.
                        Wow. Where does your dad work? I might have to see him for a paint job.
                        YouTube Clicky!!
                          Thank you!
                            Send me your info in a message I'll see if I can have him contact you. He's in Austell.
                              always glad to see someone restore of fix their accord than give up hope.
