Got a 1990 lx 5 speed with 159,000 miles that's been running on three cylinders for 5 months now. Never got to drive it on 4
. I think a piston may be damaged as there is no compression in the bad cylinder, so I just unplugged the fuel injector so I'm not polluting the world and my lungs. Now the poor neglected accord goes 0-60 in about 23 seconds, has no power under 2000rpm, and spews white smoke when the engine's cold, not to mention I have to add a quart of oil every other week. Well I've had enough of driving a car with no power so it's time for a change.
I have the full neglected cb7 story here http://www.cb7tuner.com/vbb/showthread.php?t=206631
Was originally planning on just getting a new f22 but it's very difficult to find a decent used engine without 47,500,000 miles on it, plus I discovered the H22 possibility. I was originally going to have a mechanic do the swap for me but I slowly realized that no mechanic wants to do an engine conversion so I'm doing it myself. I borrowed an engine hoist from one of my professors and bought all the tools I needed.
Here's the list of parts I have or am getting. I've done hours of research but I'm still new to this and would appreciate any advice and/or criticism.
I'll be getting just the motor because I'm a baller on a budget at the moment as I finish my final year of college, and I'd prefer better highway mpg over acceleration.
Purchased Items:
JDM H22a from hmotorsonline (with p13 ecu and downpipe)
Wear n Tear Parts
From hondaautomotiveparts,
92 SI timing belt adjuster
92 SI Bolt, timing belt adjuster spring
92 SI Bolt timing belt adjuster
92 SI plate, adjuster
92 SI bolt, timing belt adjuster base
92 SI Washer plain
90 Accord fuel filter
93 prelude sivtec parts:
hose, water outlet
thermostat assembly
Gasket therm case
Oil pump-oil strainer
oil filter
Intake manifold
o-ring upper x4
o ring 1.81
injector cushion ring x4
lower injector seal ring x4
DISTRIBUTOR
Distributor rotor
cap assy
drain plug crush washer
gasket set, head cover
Genuine Honda MT oil
Autozone,
Dayco adjuster, balance belt tensioner
Dayco adjuster, timing belt tensioner <- Won't be using
Dayco timing belt
Dayco Balance belt
Dayco Water Pump
10w-30 Castrol synthetic
NGK Iridium IX spark plugs
Oreilly,
Magnaflow Direct fit catalytic converter
Amazon,
NGK Leads
Genuine Honda power steering fluid
Ebay,
Used OEM PS High pressure line.
USautoparts
Exedy Stage 1 Clutch kit
Yonaka catback
Keeping 5 month old f22 thermostat
I want this car to be a sleeper so I'd like to keep the noise level and cosmetic enhancements to a minimum.
Engine bay as of now
Exterior as of today
. I think a piston may be damaged as there is no compression in the bad cylinder, so I just unplugged the fuel injector so I'm not polluting the world and my lungs. Now the poor neglected accord goes 0-60 in about 23 seconds, has no power under 2000rpm, and spews white smoke when the engine's cold, not to mention I have to add a quart of oil every other week. Well I've had enough of driving a car with no power so it's time for a change.I have the full neglected cb7 story here http://www.cb7tuner.com/vbb/showthread.php?t=206631
Purchased Items:
Wear n Tear Parts
92 SI Washer plain
hose, water outlet
thermostat assembly
Gasket therm case
oil filter
Intake manifold
o-ring upper x4
o ring 1.81
DISTRIBUTOR
Distributor rotor
cap assy
Autozone,
Dayco timing belt
Dayco Balance belt
Dayco Water Pump
Oreilly,
Amazon,
NGK Leads
Ebay,
USautoparts
Yonaka catback
