If you have the aem c.a.i. or i guess any other one you can increase your air flow to your intake by removing the bumper lights. You will be able to tell a slight gain in power.
What you need:
1)phillips head screw driver
2)bypass valve (if you dont already have one i would suggest it if you do this)
3)a little patience bc you do not want to mess anything up
How you do it(most of you already know)
1)take the screwdriver and go on the grill side of the bumper light and u will see a hole just big enough to fit the screw driver, loosen the screw and take it out.
2)pull the light enclosure out slowly.
3)once you have it out remove the wires running to the light and tuck them some where they will not become damaged.
4)install bypass valve
5)Enjoy your ram air cold air intake
What you need:
haha, no bumper lights for me...no tickets yet *knocks on wood*
