ok i didnt know how to take out the evaporator thought it was a hard job but its really not that hard...took me about 30 mins would of been easier but the a/c lines were a b**** since there soo old... here is the steps...
Make sure all Freon is out of the system!! or else it will end up all over your engine when u take off the two a/c lines!
1.Take out glove box (3 screws 2 are hinges underdash!)
2.take of silver cross bar behind glove box (4 screws)
3.take of two silver brackets around the evaporator (2 bolts)
4.Loosen up the a/c lines under the hood...(2 of them)
5.Take 3 nuts off the evaporator (2 on top 1 on bottom)
6.There is a lil rubber hose that runs to the bottom of the car that drops out water you need to pull that hose up from the bottom of the car soo when u pull out the evaporator it will come with it... (in the engine bay)
BAM Its out!!
If you need pics i can take some and post them up....
BAM Its out!!
