Painting a set of stock Accord alloy wheels DIY
Written by: me, of course
Tools: sandpaper (50/150 grit), 2-3 cans of your choice of color spray paint (krylon or rustoleum [if doing black, use flat or semi-flat black] OR pep boys wheel paint [better suited for gunmetal, white, etc. colors]), AND 1-2 cans of clearcoat.
The How-To:
1. Clean your wheels all around (inside and out) real good. I reccommend using a heavy duty degreaser and a scrounge pad.
2. Totally sand down your wheels (i used 150 grit paper). This will help the paint stick a little better.
3. Mask off your tires, so that you won't get overspray on them.
4. Using your spray paint, spray 3-4 light, even coats of paint onto both the inside and outside of each individual rim. Remember to wait a few minutes between each coat. Let them dry for at least an hour before handling them (they still won't be FULLY dry after 1 hr.).
5. Wait 2-3 days, and add 1-2 light, even coats of clearcoat if you want to. this is really optional though (if you want the shine/glossy look). go easy on the clearcoat though, or your wheels will become super glossy.
here's what the finished wheels should look like (flat black painted '92 EX alloys shown below):
The How-To:
