buy gauge, if gauge doesnt come with hardware then buy the oil pressure tubing kit for it, comes with tubing, and 2 brass fittings. also get a nipple/Tee fitting, this is neccessary if u plan to keep your oil pressure sensor.
remove oil filter
remove oil sensor from motor.
attach Tee fitting to nipple.
install other end of nipple into spot where the oil sensor was.
make sure its nice and snug but dont over tighten.
place oil sensor on other end of Tee fitting, tighten. place tube that was attached to oil sensor back on it.
take one of the brass fittings that came with the tubing kit on the last spot of the Tee fitting that is left.
connect tubing that came with kit into the brass fitting.
once everything is ran properly o that in, find a good location to run the tubing (oil pressure gauge tubing) thru the firewall to inside the car, but MAKE SURE, u dont break or crease the tubing (the tubing will carry oil to the gauge to show the pressure, so any tears or crease in the tubing might affect the reading or cause leaks).
i ran mines thru the whole where the cruise control line was, i nolonger have cruise control so it was easy to do.
once u run the tubing, run it to the location u plan to install the gauge at. use the other supplied brass fitting to run the tubing to the back of the gauge.
once done start the car, the oil gauge should move and the tubing that is connected to the back of it should fill with oil.
check the back of the gauge to see if it leaks, if so, clean area and turn car off and tighten till leak stops
start car again to check, if know leaks, stop cat and go back under to check for leaks around the sensor, tee fitting, brass fitting and the nipple to motor conection. if any leaks tighten til stop (also dont forget to re-install oil fiter, forgot to mention that....lol)
start car once again, let run for a minute and stop, re-check under car for leaks, if not any, u r done
now all u must do is mount gauge, and thats all up to u.
hope this helps
remove oil filter
hope this helps
New & Improved 93 Accord EX Coupe
better if I could sell some of my stuff.
