This is for the lights on the doors
Whats needed?
-Flat head screw driver
-Transparent Red paint- I used krylon stained glass
-Rubbing Alcohol
-Rag
-2000 grit sand paper
1. First pop off the the covers from the door with the flat head screw driver
2. Sand them down with 2000 grit paper
3. Clean them real well with alcohol
4. Shoot the paint like 2-3 light coats( I prefered to go darker)(inside or outside)
5. Clear them(optional)
6. Let them dry
7. Pop them back in and your done
Final Results:
Whats needed?
-Rubbing Alcohol
-Rag
6. Let them dry
Final Results:
I need a custom turbo manifold built....
. My door lights are OEM red.
