I am not finished, but just wanted to get this opened up. If you have any suggestions of what to add, post up, and I will get it into the writeup asap.
Very basic terms -
*contact patch - The part of the tire that is contacting the ground at any given time
*tie rod ends - simply put, they allow you to steer the car, they are your final connection to the wheels.
Camber
Toe
Caster
Camber is often thought of as the KILLER of tires. In reality, it is the combination of that and excessive toe.
A good way to see what I am talking about is if you have one of those ab roller wheels, like the one below. If you take one of those, and lean the wheel over while doing it.. it really isnt any harder. (this demonstrates camber)
If you turn the wheel to one side (like you are trying to turn) but force it in a straight line ahead, it is much harder to push. This is why it is harder on tires, because you are virtually dragging them across the pavement at a small angle. (this is like toe on your car)
Alignments
An alignment is just the readings of how your tires are positioned compared to each other, the center line of the car, and how they touch the ground. There are quite a few terms which get people all confused, and its a pretty good thing to know what you are talking about, especially when you have a lowered car.
Camber
Camber is a reading stated in degrees which compares how perpendicular the wheel is to the road. Here is what it means, looking at the tire from the front/rear.
The right side of the picture is the inside of the car. When your tires "leans" in at the top, it is called negative camber. When the top is pushed out, that is positive camber. To see negative camber, you have to look at the tire at eye level from the front or back of the car.
Toe
Toe in/out is the reading in degrees of how the tires sit compared to the centerline of the car. The picture below shows a car with "Toe In" since the front of the tires are pushed in towards the middle of the car. (Picture is from the top, looking through the engine bay)
Toe is the easiest to fix, all you have to do is adjust the tie rod ends which all cars come with stock. This adjustment though is the one that will make the most difference on whether your tires wear quickly.
To see toe, you would have to look from the top (on top of the hood), and see how much it is "turned" You really shouldnt be able to see the toe, or your tread will be gone in a month or two.
Caster
Caster is the reading of the imaginary line that is drawn through the upper and lower ball joints. (left side of picture is front of car)
That line that is drawn through the ball joints is angled so that when the line would meet the ground, it would do this just before the contact patch of the tire (to the front of the tire).
Doing this keeps the car stabile at speed, and makes it so the car does not wander and go wherever it wants to.
. If you turn the wheel to one side (like you are trying to turn) but force it in a straight line ahead, it is much harder to push. This is why it is harder on tires, because you are virtually dragging them across the pavement at a small angle. (this is like toe on your car)
