- Provided by JDM Fan.com
Installing GReddy Oil Catch Tank
Purpose:
A catch tank (or can) works just like a crankcase vent filter. It will bypass the connection between the crankcase and the air induction intake track. This will relieve pressure place against the valve train under engine load. But unlike a crankcase vent filter, the oil used by the valve train will not drip onto adjacent engine components. The oil catch tank will ‘catch’ the oil and moisture in the blow-by gas that cause carbon and sludge build-up in the intake system and the engine. This will keep your engine compartment clean, your performance maximized, and give your engine that custom look.
Materials:
- GReddy Oil Catch Tank w/9mm hose (#12003506) $83.00
- GReddy Universal T Bracket (#120035TB) $5.75
- Possibly extra fuel line hose (Home Depot)
Parts included are:
- Polished billet aluminum oil catch tank
- 3 foot of 9mm hose
- Sight hose
- 9mm Earl's Hose clamps (2)
- Sight hose fittings (2)
- Set screw (acts as plug)
Shown configured for vertical mounting
Shown configured for horizontal mounting
Sight hose installed and tank ready for mounting in a vertical position.
Note:
In either mounting position, vertical or horizontal. The sight tube must be installed in a vertical fashion.
Find a suitable location to mount the tank and either use the "universal t bracket" from GReddy or fab up something on your own.
Once a location is found measure the distance required for both hoses (one to valve cover fitting and the other to the intake fitting) and cut the hose to proper length.
Mount the catch tank to your desired location.
One side of the catch tank is routed to the valve cover fitting with proper hose clamp installed.
The other side of the catch tank is then routed to the intake fitting with proper hose clamp installed.
Notes:
- As far as we know, its completely smog legal in all states.
- When correctly installed, all crankcase fumes are routed back into the intake to be burned. Only the oil is separated out.
- Please dispose of any waste oil properly.
Purpose:
Materials:
Parts included are:
- Sight hose
Note:
Notes:
