ENGINE BLOCK:
Front Balance Shaft Pulley Screw >> 22 lb-ft
Timing/Balance Shaft Belt Tensioner Adjuster Nut >> 33 lb-ft
Camshaft Pulley Screw >> 28 lb-ft
Connecting Rod Nuts >> 34 lb-ft
Crankshaft Pulley Screw >> 162 lb-ft
Oil Pan Screws >> 10 lb-ft
Oil Pump Backside Cover Screws >> 62 lb-in
Oil Pump Housing Screws >> 9 lb-ft (108 in-lb)
Main Bearing Cap/Bridge Screws:
- Step 1 >> 22 lb-ft
- Step 2 >> 55 lb-ft
ENGINE CYLINDER HEAD/MANIFOLDS:
Spark Plugs >> 13 lb-ft
Exhaust Manifold Nuts >> 23 lb-ft
Intake Manifold Nuts >> 16 lb-ft
Valve Cover Acorn Nuts >> 9 lb-ft (108 in-lb)
Water Pump Screws >> 9 lb-ft (108 in-lb)
Camshaft Cap Mounting Screws:
- 6mm Bolt >> 9 lb-ft (108 lb-in)
- 8mm Bolt >> 16 lb-ft
Cylinder Head Screws:
- Step 1 >> 29 lb-ft
- Step 2 >> 51 lb-ft
- Step 3 >> 78 lb-ft
DRIVETRAIN:
Flex Plate Screws to Crankshaft (Automatic Transaxle) >> 55 lb-ft
Flywheel Screws to Crankshaft (Manual Transaxle) >> 76 lb-ft
Front CV Shaft Nuts >> 180 lb-ft
Transaxle to Engine Bolts >> 47 lb-ft
Manual Flywheel to Pressure Plate Bolts >> 19 lb-ft
Intermediate Shaft Bolts >> 28 lb-ft
FRONT SUSPENSION:
Radius Rod Nuts >> 32 lb-ft
Shock Strut Rod Nut >> 20 lb-ft
Shock Upper Mount Nuts >> 28 lb-ft
Shock Lower Mount Bolt >> 47 lb-ft
Lower Ball-joint Nuts >> 47 lb-ft
Upper Control Arm Mounting Nuts >> 47 lb-ft
Upper Control Arm Ball-joint Nuts >> 32 lb-ft
Outer Tie-rod Ball-joint Nuts >> 32 lb-ft
Knuckle-to-Hub/Wheel Bearing Assy Screws >> 33 lb-ft (snug evenly until flush, then final torque)
REAR SUSPENSION:
BRAKES/WHEELS:
Wheel Lug Nuts >> 80 lb-ft
Front Caliper Screws >> 54 lb-ft
Front Caliber Bracket Mounting Screws >> 80 lb-ft
CB7 Timing Belt Procdure
CB7 Tune-Up Specs
CB7 Fluid Capacities
DRIVETRAIN:
FRONT SUSPENSION:
REAR SUSPENSION:
BRAKES/WHEELS:
CB7 Tune-Up Specs
