Air Cond Refrigerant
R-12
- 29 OZS.
Automatic Transmission Fluid
DEXRON II ATF
- 2.5 QTS for drain and fill.
- 6.3 QTS for overhauled transmission.
Brake Fluid
DOT3 or DOT4
- Check and Refill
Fill to line on reservoir.
Engine Coolant
50/50 mixture of Genuine Honda Antifreeze/Coolant and water
Automatic Trans - 3.7 QTS.
Including the coolant in the reserve tank and that remaining in the engine. Reserve tank capacity: 0.16 gal.
Standard Trans - 3.17 QTS.
Engine Oil
SAE 5W-30 (Preferred) (Below -20Deg.F to above 100Deg.F), 10W-30 (Above 20Deg.F)
w/Filter - 4 QTS.
w/o Filter - 3.7 QTS.
Fuel Tank
- 17.04 GALS.
Manual Transmission Fluid
API SF or SG grade motor oil with a weight of 10W-30 or 10W-40
- 2 QTS.
Power Steering Fluid
Genuine Honda Power Steering Fluid
- Check and Refill
Windshield Washer Fluid
Good quality commercial all weather washer fluid
- 2.6 QTS.
Follow the Manufacturer's Instructions for the mixture ratio.
CB7 Timing Belt Procdure
CB7 Torque Specs
CB7 Tune-Up Specs
CB7 Fluid Capacities
