lokuputha : 1990 Accord EX
    Welcome!
    PICTURES ON EVERYPAGE!!!
    Best Viewed on a 19" Monitor with 1280 x 1024
    Dial-up ppl, u've been warned
    MoD LisT:
    ENGINE & DRIVETRAIN:
    -1993 Honda Ascot 2.0Si DOHC F20A
    -1993 Honda Ascot 2.0Si 5-Speed transmission H2J4
    -150 hp @ 6100 RPM
    -137 ft-lbs @ 5000 RPM
    -6700rpm redline
    -Compression 9.5:1
    -Bore: 85mm
    -Stroke: 88mm
    -Honda Gasket set
    -Custom 19T Waterpump
    -Cruise Control Deleted
    -A/C deleted...well not really...its broken
    -DC sports 4-2-1 header
    -Magnaflow Catalytic converter
    -RS*R Exmag Stainless Steel Satin Black Cat-back Exhaust
    -Prelude Starter motor
    -200Amp high current Alternator
    -DA Integra Airbox with 3-way intake tubing, Crown Vic Venturi Tube
    -short throw stock height shifter from yeamans17 :: crazy mod! recommended
    -Battery Trunk Relocation
    -New HONDA OEM drive shafts
    -AC removed (almost, it hasn't worked for 4 years)
    -new VSS and drive unit :: there is a weird ticking and the old drive gear was warn down??
    -UBER DUPER valve adjustment Oct 2008:: extra torque and lower NVH
    -new coolant lines
    -new soft power steering line :: does the job
    -exhaust gasket set
    -New Honda OEM VSS
    -New Honda OEM VSS drive gear
    EXTERIOR:
    -Redone 90-91 Accord Color: Cappuccino Brown Metallic Clearcoat YR-501
    -1995 Acura Legend Sedan Front Lower Lip
    -1993 CB9 front bumper
    -1991 CB Japanese 1-pc headligts
    -1993 CB9 amber turn signals
    -1993 CB9 fog lights :: wired
    -2.0Si badge
    -Satin black accents & badges
    -new windshield ::windy day + open hood = cracked
    -new Original Honda Hood
    -Junk Yard quarter panels
    -Lexus rear projector fog light :: check. now I need to install it.
    -Honda OEM mud guards
    -CB3 Chrome front Grill
    -CB3 brown tint windows ::driver side installed, 3 more to go.
    INTERIOR:
    -Original Honda Accord Light Beige Mouse-fur seats
    -Brown Dash & Highlights (EX model)
    -New Shift Boot!
    -CB9 Fog light switch :: check...too lazy to install
    -CB9 Half Antennae switch :: check...no antennae to install
    -Tan Color 6.5" Rear Speaker Pods
    -new used Black Plastic dash
    -Broken Speedometer :: check...too lazy to fix
    -1st Gen ITR steering wheel :: great upgrade....highly recommended, now I need to setup the horn.
    -1991 Toyota AE92 Red Sports Seats ::installed, needs a cleaning
    -Astrovannin custom seat brackets :: Thanks Dustin!
    -new driver door control module :: my mirrors don't go crazy anymore
    -1993 CB glove box damper
    -1993 CB tan sun visors ::looking for ones with lights
    SUSPENSION/WHEELS:
    -Ol'school Racing Hart D/Spec Superlative Racing Dish 16x7.5 with 35mm offset
    -Bridgestone Potenza G009's 205/50-16 gummies
    -Replacement Honda Ball joints and control arms
    -Tein H-Tech Springs
    -Tokico Blue, HP shocks
    -Goodridge Stainless Steel Brake lines (a really good modification for any CB)
    -Honda Rear Drum Assembly
    -STracing Sway bars :: need to powdercoat them b4 install
    -Poor-man's Big Brake Setup :: kiss the windshield::
    -1994 Acura Vigor 11.1" front rotors
    -1994 Acura Vigor Honda Remanufactured Caliper Assemblies
    -1994 Acura Vigor Honda OEM Brake Pads
    AUDIO/ELECTRONICS:
    -Security....undisclosed military-style security system.
    -Clarion Mp3 deck (will get model number)
    -Clarion Pro Audio 6 1/2" components up front
    -PPA 6 1/2" Mid Woofers with Planet Audio Crossover & Tweeters
    -15dB Radio Antenna Amplifier
    -Kenwood 800W 4-Channel Amp ***love it, don't need a sub anymore***
    FUTURE PLANS:
    -12" Kicker Comp C12 sub
    -Pioneer GM-3300T 2 Channel Amp :: picking up tomorrow.
    -Honda Ascot Instrument Cluster
    -Honda Ascot 2.0Si Prestige emblem
    -Honda Ascor 2.0Si F20A DOHC Variable Valve timing unit
    -PT2 ECU
    -engine wash & detail
    -paint valve cover
    -Honda replacement antenna
    -roll rear fenders
    -fog light HID's
    -Rear disk swap
    -Hondata engine management
    -suspension overhaul
    -LED bulb transplant
    NOW
    DEVOTE
    FS: Lokuputha's Stuff
    wow, what a transformation. the quarter panel was scary, now your car looks great. i've never seen those kind of rims before, they look good with your color. your first pics or your car don't look anything like what it is now. great job man!
      damn those are some sick rims
      thats a lot work put into this car good job man
      Members Ride
        Thanks a lot guys. I really appreciate your acknowledgement.
        Yeah the rims I found from a collector up here in Toronto. Lucky me I guess.
        this is what the car use to look like.
        THEN:
        DEVOTE
          those rims are cool. i like how they keep the essence of the OEM wheel. nice rust repair to. later.
          Avoiding dirt at all costs
            Yeah the rust repair was the big one.
            One of my family friends deserves credit for that one.
            Actually he should be joining this forum any day now.
            He's got a fine 1993 Accord EX-R with all options including the beige leather.
            DEVOTE
              wow. crazy transformation. great job!!!
                Nice job with the restoration work. Keep it up!
                Always remember that only you can make your dreams a reality.
                Never forget that your style is all that matters when it comes to your ride, but be respectful to others who don't share your vision.
                Proud Alum of the University of Texas at Tyler, Class of 2010
                  looks real good. nice transformation aswell. wheels are hot. i was saying to myself that those wheels dont look right then i had to do a double take on the first pic again.
                    thank you
                    DEVOTE
                      damn...those rims are HOTTT.......good job on restoring the car!!!
                        here are some more pics...
                        i really need a good camera; any suggestions...
                        my cell camera is not going to hold up for long...
                        enjoy
                        this is the JDM spider that fell out of my CB9 bumper!
                        DEVOTE
                          nice spider! having that thing alive in another environment can really affect well the environment. imagine the cross breeding!
                          nice wheels!!! very nice indeed. let me know if you decided to sell but overall the car has transformed nicely. any engine bay pics?
                          1cor10:31
                          - 92 LX coupe
                          - 96 EX wagon (sold)
                            I still have to clean up my engine bay,
                            the body work left it all dusty.
                            Interior dirty as well.
                            Give me some time...school just started...
                            Hahaha...THE wheels won't be for sale for a while...
                            I was going through your wheel list...pretty good collection
                            specially the "14" stock LX steelies with hubcaps"
                            DEVOTE
                              Here are some more pictures...doing the best I can with my cell phone skills.
                              Check out the Classy Nova behind.
                              Whats a trip to Staples Business Depot without the "easy" button!
                              School started...need books.
                              Lakehead University Residence: Bricks and dead grass.
                              DEVOTE
