im thinking about turbo'ing my f22a6 motor...i want to make it somewhat turbo ready...meaning that i want it to handle about 12psi daily...i kno i have to rebuild the block, but does any body have any tips and/or suggest on wat i should go about building the block and wat engine parts they recommend...im also open to any other suggestions on preping my car for a turbo setup...
my spending limit is about 600 dollars on the engine...is that ok or am i just wasting my time...?
edit: 8psi daily
EDIT EDIT: im gonna run 15psi daily and its carved in stone...just gotta get a good tune...
theres alot of bs on this thread with ppl going off topic and sht...but wat eva the case...if read through this thread you might find some very helpful info about the built f22 turbo process...and if knowledgable...you will see some of my ignorance at the beginning of this thread but in time u will see my progression of the turbo build...
Parts List:
9.0 Wiseco Forged Pistons
H-beam Cat Rods
GT3271 Garrett Turbo
Turbo Manifold
ACT Heavy Duty Clutch Kit
255LPH Walbro Fuel Pump
AEM Fuel Rail
H23 Intake Manifold
ARP Head Studs
Full Gasket Set
Waterpump
Timing Belt Kit
Alternator Belt
Crankshaft Dampner
Questions about Building the Block: page 1-5
Pulling the motor out and the Turbo Build Process: page 6...
PICS: page 6 and 7
edit: 8psi daily
Parts List:
H-beam Cat Rods
Turbo Manifold
AEM Fuel Rail
H23 Intake Manifold
ARP Head Studs
Full Gasket Set
Waterpump
Timing Belt Kit
Alternator Belt
Crankshaft Dampner
PICS: page 6 and 7
