Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 07-05-2004, 03:52 AM   #1
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
EXT: OEM Fog Light installation (USDM 9293, others similar)
let me mention right now that this may not be the "proper" way to install them, we know there are OEM templates available, but we didnt have them, and we installed them our own way, and it turned out great. so this is how mauricio (excalibur02) and myself installed some pretty OEM USDM 9293 fogs on his car... so all the pics you see are of his car, not mine :P so yeah, on with the DIY!
timmy0tool did a followup DIY thread with better pics and a little more info, so take a look at his thread too: http://www.cb7tuner.com/vbb/showthread.php?t=15489
Required tools/parts:
- dremel with cutting disc and sanding wheels
- hacksaw blade
- ratchet set/wrench to remove bumper
- wirecutters / strippers / electrical tape / stuff for wiring
- APC foglight wiring harness kit
- the fogs, with brackets and connectors
STEP 1 : remove the bumper following the other DIY guide by usc
STEP 2 : get yourself prepared for where the bumper will be cut. this is an overlay pic so you can see where the edges of the fogs will line up. if you look at some of the later pics, youll be able to see how it turned out. the second pic is of the rubber trimming that gets installed around the fog... it should also help give an idea how itll be installed. EDIT: OEM bumpers have a faint trace outline on the backside of the bumper, its like a faint double dotted line showing where the bumper is supposed to be cut. i dont know if you should cut along the inner or outer line, try the inner one first... if the foglight doesnt fit, you can always use a dremel and extend the hole to reach the outer dotted line
STEP 3 : cut the hole out, but just the general shape, but make sure you stay "inside of the lines" - the hole will be trimmed down and rounded and perfected later. if you have the OEM bumper, follow the trace lines on the back side like mentioned in step 2. aftermarket bumper ppl, youre gonna need to guess.
STEP 4 : use a dremel with some sort of medium to heavy sanding cylinder on it, and trim down the edges of the bumper, rounding it out and makign it the perfect shape for the fogs. when you get it done, the rubber trimming (pictured in step 2) should fit perfectly into the hole and stay in place. youll start gettign a feel for it as you try. thats me with the dremel, wearing the cheesy goggles... i got a chunk of melted bumper plastic in my eye, and that wasnt fun... so USE GOGGLES... melted shards of plastic fly everywhere.
STEP 5 : test fit the fog light. the bracket on his fogs (USDM 92-93) had 3 screw holes along the bottom, two on the top corners, and one center brace on the top center. when reinstalling the bumper, one of the bolts that went behind the bumper lights gets put thru the top center brace on the fog light bracket, and it helps hold it. for some reason the top two corner screw holes didnt line up, so those brackets were bent out of the way, and only the 3 bottom screws and the top brace were used. its very solid.
STEP 6 : wire them up! mauricio's friend had given him an APC fog wiring kit, so we used that. it had the switch and wiring harness all pre-set up. im not going to explain how to make your own harness, i say just go out and buy the APC one, it made life SO easy, just run the wires and plug them in. the connectors that came with the fogs need to be spliced onto the ends of the APC wiring harness. right now he is using the APC button to control them, but he has an OEM fog switch and connector... when we get a chance to wire that up in place of the APC button, ill post up a diagram of where each pin gets connected. you can barely see the two white wires hanging out of the corners of his car, ready for the bumper to be installed and the fogs hooked up.
Old 07-05-2004, 04:02 AM   #2
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
heres some "eye candy" - pictures of the finished product. it made his front end look much better! dont mind the absence of his front grille... its being DIYed.
oh yeah he also got a 94-95 OEM lip installed that night
Old 07-05-2004, 12:42 PM   #3
accordtunerx
CB7tuner.com Founder (Former Owner)
accordtunerx is cool... so far.
wow, awesome addition to the DIY forum guys!
i'm sure it'll help out a lot of people... or at least the ones that are lucky enough to get their hands on a set of those fogs..
they look really good mauricio... and i really like the 5th gen lip too. your car is coming together nicely. now you just need that DIY grill to really set your front end off
accordtunerx is offline   Reply With Quote
Old 07-05-2004, 12:57 PM   #4
RollingStock
RollingStock is cool... so far.
Send a message via AIM to RollingStock
looks good
86 nissan 200sx turbo
RollingStock is offline   Reply With Quote
Old 07-06-2004, 02:54 AM   #5
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
now correct me if i'm wrong here but i heard there is a template or outline on the backside of the bumper to show where it needs to be cut for the foglights. did the bumper have this? do all bumpers have this (USDM and JDM)?
great DIYer! i might just have to cop a set .
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 07-06-2004, 02:57 AM   #6
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
eh... people say that OEM bumpers should have an outline on the back, showing where to cut... but we couldnt find anything similar to that... so who knows (his might be aftermarket?). also there is a paper template from Honda, idk if you can still get it from them, but a few people on this site have the template... i guess you lay it down and make the outline or something, not sure. we didnt use any template, cut out the general shape, and kept doing it little by little until it fit the fog light properly. eh, i guess it worked... lol.
Old 07-06-2004, 03:14 AM   #7
Prez808
Location: Finally back home in the S.F. Bay Area (510)!
Prez808 is cool... so far.
Send a message via AIM to Prez808
I have the template. Scanned it tonight. I will put it up soon after I join the two scans since it's so long.
Funny, I have different rubber surrounds on my kit.
It's more like a tubing that's split down the middle and made to pinch the opening.
Prez808 is offline   Reply With Quote
Old 07-11-2004, 07:22 AM   #8
PRIMOCB7
PRIMOCB7 is cool... so far.
Send a message via AIM to PRIMOCB7
those lights look really good..makes me wanna buy back my bumper from you
5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
PRIMOCB7 is offline   Reply With Quote
Old 07-11-2004, 10:41 AM   #9
Maple50175
Gigity Gigity
Location: Good ol' Ma. Does it look like im kidding assholes! XM-BPM for life!
Maple50175 is cool... so far.
Send a message via AIM to Maple50175 Send a message via Yahoo to Maple50175
damn i want oem fogs. If anyone has any for sale Pm me !
Maple50175 is offline   Reply With Quote
Old 07-11-2004, 07:30 PM   #10
excalibur02
Wanna be JDM whore
oh shit wuts good guys i didnt know this was made lol. thanks mike for the diy. it was easier than i thought when we did the install.
i got a digi cam so when its nice and clean i will take pics of my car and make a new sig lol that sig is mad old
so thanks for all the comments guys
mauricio
Instagram username MAURO02
Old 07-13-2004, 01:26 PM   #11
dookie320
dookie320 is cool... so far.
Send a message via AIM to dookie320
nice write up and pics
dookie320 is offline   Reply With Quote
Old 10-03-2004, 05:40 PM   #12
VRDrvr
VRDrvr is cool... so far.
Send a message via Yahoo to VRDrvr
Can you rehost pictures please
No more cb7, 7 years of ownership and 196K on the ticker before she was sold
Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
NREMT-B | 300D and some glass
VRDrvr is offline   Reply With Quote
Old 10-03-2004, 08:19 PM   #13
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
taken care of
Old 10-03-2004, 08:28 PM   #14
VRDrvr
Thanks cpmike ....I think the 9091 would be easier mainly due to the "cutout" is kinda already there.
example pic:
Mike, how would you rate this install...based off someone with common wiring knowledge etc. (basically the hardest thing to date I have done has been brakes and 5th gen lip install )
Old 10-03-2004, 11:41 PM   #15
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
twas very easy... used a hacksaw blade (handle not attached) to cut the general shape, then a dremel to round it out. besides that, the foglights just screw in. most people would be able to handle it.
Old 10-04-2004, 01:14 AM   #16
excalibur02
Wanna be JDM whore
well i havent had time to make a members ride page so here is a recent pic of my setup at night. its a little blurry but if u need more info or pics feel free to ask
mauricio
Old 10-04-2004, 08:14 AM   #17
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
example pic:
I did mine in about an hour. The hardest thing was removing the bumper for the first time. I had OEM wiring, but I'm sure its just as easy as aftermarket. I just used a razor to cut out the black pieces under the bumper light, then it just screws in. Its so simple, but an awesome mod. Any more questions, just ask.
AccordWarrior is online now   Reply With Quote
Old 10-04-2004, 01:32 PM   #18
timmy0tool
i took my bumper off and saw the outline. it is confirmed that there IS an outline/template on the backside of the bumper. here are some pics showing it. it might be hard to see but it is there, trust me. mike, maybe you do have an aftermarket bumper .
1cor10:31
- 92 LX coupe
Old 10-04-2004, 01:55 PM   #19
accordzoom
accordzoom is cool... so far.
great DIY, been waitin for it
also timmy that link isnt accessible for non imagestation users
accordzoom is offline   Reply With Quote
Old 10-04-2004, 03:50 PM   #20
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
actually at first glance we looked and were like BAH theres no outline... but at closer look, yeah, its definately there, but very faint. its kinda a double dotted line. ill add that to the first page of the DIY.
and side note, theres also the outline for the oval fogs
