Originally posted by According2Aaron
View Post
For the partitions... Once you have set the partitions and started using them, you will have to format the drive to change the partitions. Thus loosing all your data if you do.
Partitions separate a single physical drive into 2 or more logical drives.
For example... You started with one 200 GB hard drive, C:
Now you partitioned it into 2 separate drives 100 GB each. Now windows shows C: and D:, both 100 GB. But you still have only a single physical 200 GB hard drive.
Really the only reason to partition is to separate operating systems...
To dual boot Vista and Linux, you will have to make 2 partitions, and install Vista to one, Linux to the other. You should read up on how to dual boot systems before finalizing anything.
As for how big you will want to make the partitions... 2 Questions... How big is the hard drive, and which OS will you find yourself using more?
