cb7 howstuff works
hmmmHonda Accord Reliability
Audio system (1990, 1991, 1992, 1993): The CD changer in the trunk, a dealer installed option, may not eject; CD magazines will be exchanged for redesigned units.
Automatic transmission (1990, 1991, 1992, 1993): Cars with high mileage may begin to shift more harshly; this may be corrected by adding a bottle of Lubeguard conditioner to the automatic transmission fluid.
Brakes (1993): The parking brake may not fully release because a rivet on the brake rod is too tight.
Engine noise (1990, 1991, 1992, 1993): A squealing noise from under the hood is likely to be caused by a worn alternator bearing; it may have failed because the belt tension was too great.
Steering noise (1990, 1991, 1992, 1993): If there is a squeak or squeal in the steering, especially when making a slow, tight turn, look for a label on the power steering reservoir that says PSF-V additive was added. If the noise is still present after additive was installed, the right-side end seal on the steering rack will have to be replaced.
Honda Accord Safety Recalls
1990, 1991: Front seatbelt release buttons can break and pieces can fall inside.
1991 wagons: Improperly attached washer in cargo area light may have fallen inside during assembly; if tailgate is open and switch is in its middle position, washer can cause short circuit that causes switch to overheat, resulting in fire.
1991, 1992, 1993 wagons: Rear outboard seatbelts may lock-up at angles other than those required by federal standard; this could increase risk of injury in a sudden stop or accident.
1992: Left seatbelt assemblies on a few cars were installed on the right side; as a result, the belt cannot be pulled out of the retractor, making it unusable.
See the next page to find out about the 1994, 1995, 1996, and 1997 Accord, a generation that saw, among other things, continued advancements in styling.
For advice, reviews, photos, prices, reliability trouble spots, and even examples of used cars you're considering that are on sale in your area, check out:
93 Accord LX Sedan (sold)
wow...didn't see that part of it....
won't honda fix that under warranty? I know when my seatbelt was super worn it got fixxed for FREE!!! nothing like getting warranty work done on a (then 13)year old carOriginally posted by stewie View Postwow, i have a 90 and my frotn seatbelt clip is broken
__
__
Is that what that fucking supercharge like whine was coming from?! FAWK
Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
Originally posted by JoshMOkay to do: "I'm sorry I broke your mailbox, here's $100.
NOT okay to do: "I'm sorry I fucked your sister, here's $100.
Honda has a Lifetime Warrenty on the seat belts, excluding cosmetic issues.Originally posted by bcjammerx View Postwow...didn't see that part of it....
What is Honda's reasoning for doing this in the US?Per Honda policy, the Accord offered no factory optionsLast edited by Accrdwgnguy; 06-16-2009, 05:44 PM.
Bitchin!
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
