4 cylinders, 2 turbos, 1 supercharger= OMFG!
repost
Looks beautiful. A+ craftsmanship. If he gets it to run as good as it looks, I'm sure reliability won't be much problem.
Mayhaps that huge drivebelt could use an idler pulley for that long open run.
Originally posted by NutBucketI do believe that's the point of the supercharger; to combat lag.
I'm not even going to acknowledge the "slowbaru" comment...
This SC is a good idea for a street setup, but for track use, well, its better to use a single properly sized turbine, and theres less shat to go bang. If your really smart, you wont use a Boxer at allLast edited by Dv8; 04-23-2007, 02:21 PM.
Engine looks too cluttered. Makes the subaru engine look even more confusing...
ya generally the supercharger is used the spool bigger turbines in a method call twin charging. old audis used to do it back in the day for rallys i believe and a past issue of sport compact mag. had a turbocharged mini cooper S called the "twinie" there is so much math included with twin charging that it will make your head spin. just find that issue of SCC mag and read the article. you mind will go numb.
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
yeah, the turbos run off of a super which runs off of the belts....
someone ought to make that into one unit, they could call it a procharger!!
erm....
anyways this is the rest of the car...
http://forums.vwvortex.com/zerothread?id=2180560CB7
Removed:A/C, P/S, C/C, ABS, Wires, Battery
Added: H22A, South Bend TZ Series Clutch, Fidanza (8lb) Flywheel, Megan 4-1 Headers
Waiting For:M2F4 Tranny, NX 50 Shot
Wow looks hot dude..i would LOVE to see a video thread...accordtypeR aka Seve aka The Godfather.
My Old Baby....................My New Baby
SOLD TO..grumpy93, iceplaya123, slr_theking, tn_accords
Originally posted by Dv8Easier, more efficient, and less costly way of spooling your massive turbine; NITROUS. It's sad people dont realise this, even more sad that people lack the brains to make it work.
