Ive noticed, that my clear coat is slightly starting to haze. Its not frosted, crakling or peepling, yet! Its just starting to haze lightly. Its on the top of my car and toward the rear window next to the trim. Peeps dont really notice it, but its my car and I can stare at it all day if I want to. Im abit concern, what are my options here. Anyone?
clear coat haze
If you dont have a buffer you can try doing by hand... must do it really fast though. lol
They best option is to have a professional detailer shop do for you... and have them give you the wax to protect it from future paint fading.Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
I got a buffer also. Im a DYI kinda guy, thats why Im in here. Im thinking of doing it by hand with rubbing compound. It will remove the top layer and exposing the bottom part of clear coat. Doing it by hand the area in quiestion and buffing the remainder of the car. Would it possible the same issue continue to happend (haze), if not treated correctly?
Post a pic of the haze... chances are it already too serverley damaged. Usually when it haze.. it will come back. If it's not too bad yet you might be able to buff it out.. put some nice coats of wax on it might help to cure future fading and haze. The reason it haze is basically your cear coat has no more UV protection..or at least the sun has burn it off and making it dull aka haze.Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
The haze if being caused from the uv rays breaking down the clear coat causing the clear to become very thin. You have two options, one is to buff out the area with a buffer on very low speed with a glaze rather than compound. The glaze is more of a thinner less coarse material that is made to make the clear shine. Compound is more for polishing away scratches caused from sanding, if you get a real agressive compound and start going to town chances are that your going to make matters worse. Try a glaze first on a low speed buffer with a soft black pad, any paint supplier will know what your looking for. Another note about fading of clear is that once it starts it will continue no matter how much wax you use, the clear is breaking down causing it to loose the shine. The other option is to save up and paint but that gets pricey.
Well? I know Im gonna paint it someday, but I want avoid doing that for time being. My car is not perfect, its got, minor dents, scratches, obrations on the both front and rear bumper. For being a 19 year old car, it looks pretty decent. I even got original 92 replacement hub caps. I just baught a 91cb7 sedan 4 $300 bones, but its gonna take time and money. Eventually, Im gonna preserve my 92 cb7 for the next 20 years. But its age is starting to show abit.
Im gonna try to buff out and see what happends. Either way, I will com back and post up my results.
Thanks
Im back & started on this very two yeard old clear coat issue. I did this same job on a project car I flip two years ago, it came out so & so. This is my second weekend, im taking my time taking off flaky white cleak coat exposing the clear coat that looks transparent showing the paint at the bottom, I have also removed the center spot ring oxidized top paint to (clear coat is gone), to match the outer circle. Im gonna clean & polish the entire area before I spray on some clear coat. It can happened but its time consuming and you need to develop hand & eye coordination. That's it!
Im goona polish the remainder of my car, the clear coat still looks good thought it looks abit fuzzy.
Anyone have feedback.
Thanks.
