Hey guys I was wondering if the the front bumper from a 92 or 93 will fit the same on a 91 ex model? I want to swap them as I have the fog lights off a 92 accord.[IMG][/IMG]
Front Bumper
Originally posted by oaxaco1985 View PostHey guys I was wondering if the the front bumper from a 92 or 93 will fit the same on a 91 ex model? I want to swap them as I have the fog lights off a 92 accord.[IMG][/IMG]
The 92-93 bumper has a tiny lip where the grille sits. You can still utilize a 90-91 grille however you will often times find the front grille "tucking" itself behind the lip unless you adjust your headlights to sit a little more forward to adjust for this.
If u just change out the grille, then the headlights will be off a little because the 90-91s go |--h--| while the 92-93 is more like \--H--/ and it will leave a gap.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
I've given you a more descriptive title and moved this to its correct section. This is information that would have easily been found with even a minimal effort search.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by oaxaco1985 View Postok so I need to change everything now I can get a price for the hole front end at the yunk yard thanks
If oem foglights are the only thing you want to put on your car, you could try selling them on e-bay and get the 90-91s that would fit your bumper already to save you the hassle of paint etc. A The 92-93's seem to be the ones that go for the most coin on e-bay and this forum. I've seen a set of 90-91s go for $150 just recently. You could probably make $200ish for some USDM's and then use the spare change for some other mods.
You could also see if someone local would trade you.
"The JDM Fleet"
I've done this swap. And everyone says you don't need to change anything. That didn't make sense when I tried to put the 92-93 bumper cover on my 90-91 bumper support. They did not fit together, so I had to go to a junkyard to pick up the right part. I even compared the two bumper supports after I bought it, they are different and will cause fitment issues for the bumper cover itself.
I HAD to change out the bumper support. The 90-91 bumper support is taller than the 92-93 and therefore, the 92-93 bumper cover does not fit on the 90-91 bumper support. At least, this is what I HAD to do to get the bumper to fit. I didn't change the headlights, grill, or corner lights and you can notice the gaps, but it isn't terrible. I could post pics if you need...
PS. Don't tell me I am wrong. I have done this swap. I know what it needs in order to be done and what it takes to have it fit perfectly.
(maybe it could just be my car, but the same thing happened when I was test fitting bumper covers in the junkyard. I test fitted a 92-93 bumper cover on 3 different 90-91 bumper supports, they don't work. Only 92-93 bumper supports worked).Last edited by oni_cb7; 03-20-2013, 07:17 PM.
Originally posted by oni_cb7 View PostI've done this swap. And everyone says you don't need to change anything. That didn't make sense when I tried to put the 92-93 bumper cover on my 90-91 bumper support. They did not fit together, so I had to go to a junkyard to pick up the right part. I even compared the two bumper supports after I bought it, they are different and will cause fitment issues for the bumper support itself.
Originally posted by Shadow1992 View PostMaybe because you were just swapping the cover? Most people consider the cover and the support as a whole 'the bumper'. In that case you wouldnt need to change anything since the support attaches to the car in the same manner for both styles.
