DIY on how to take appart the front door panel?
    Any 1 know where can I get a DIY to take appart the front door panel? I could obviously improvise, but I dont want to break stuff...
    Thank
    on gas pedal, IMHO my ride looks awesome altough its 100% stock, its cleanliness and its frost white color are the only mods I need....
    Help me get a free xbox 360!!!!
    http://xbox360s.freepay.com/?r=31326965
    haynes manual from advance/autozone
      Check this link out
      http://cb7tuner.com/vbb/showthread.p...ght=door+panel
      I dont know if you have power windows or Manual but there ya go!
      -Lam
        Its still pretty straightforward. Plastic plug type deal under the mirror (dunno the proper term for it), Screw in handrest, Door handle, and lower corner. You will need a small flathead to pry the covers of them out. When pulling the door handle off pull it toward the front of the car so it will unhook. Take off the power lock plug in the back, Get you something to move the plastic clip thing over and pull out the metal rod. AFter that should be able to unclip the door and it should come off.
          If you dont have power windows then dont forget about that damn C clip the holds the window crank on. That can be a bitch to get out, lol. I just wrap a rag around it and pull and it usually unhooks the C clip.
          My FB Page - http://www.facebook.com/hellaflush3d
          My 3D Work --> http://samauripizzacats.deviantart.com/
            Thanks a lot guys, I have power windows so I guess it makes it easyer, I would like to change both my speakers....
            I would also like to change the exterior door handle (actually just swap the passager one) because the one on the drivers side is very old and feels all stiff, the one on the passager side works like new, can I do so? if yes will I be able to keep my powerlock doors? I have a 1993 EX CB7...
            Also do I need to pull te panel really hard for it to unclip, or which movement is more apropriate to take off the panel in the most undamaging way?
            Thanks
              i dont think you can swap the passenger side handle to the driver side because it a mirror image of the driver side so it wouldnt fit...but i dont know what it looks like so who knows. lolz
                fyi: door panels are very easy to remove on almost any vehicle, they are pretty much all the same, there are plastic plugs that run around the edge of the panel. get a panel popper (the "right" way) from sears or most any hardware stores, 99% of the time i dont even use any tool other than a drill to take out screws. u just get ur finger under the edge of the door and yank the bitch off, be gentle but dont be afraid to pull it. the door handles usually slide to the side and pull out easily (make sure u remove any screws holding it. im just tryin to help anyone i can with this, i know youve prolly got it off already. i install speakers, stereos, amps, all that mobile electronics crap for a living so if you have any other questions i can try to help. peace guys
                Member Ride Facebook
                XBOX LIVE = RedDragonsFool
                SOLD MY CB JUNE 16, 2009
                For Sale Thread
                  Spray some lube on the door handle when you take off your door panel. Try some WD40 or something.
