Bolt Pattern and Tire Size Question
    Before I start my thread that would help me choose a good set of rims and tires, I need to know a few things as stupid as they may sound.
    First, what is the bolt pattern of a CB7? I know there are 4 bolts but what's the distance (in measurements used for for rims and tires which I think are millimeters) between each of them?. Of course I could measure that myself but the car is sitting in the garage for winter and I just don't feel like going out there with a ruler or measuring tape.
    I would also like someone to very clearly explain to mean how tires measurements work if I'm wrong.
    Example: 205/40/17.
    From what I think I know, except for 17, those are measurements in millimeters am I right?
    205 would be the width of the tire while 40 would be the offset which is the distance from the inside lip of the tire to the top is that correct?
    Thanks
    NEW MYRIDE THREAD
    PARTS 4 SALE
    40 stands for the percent of the read width. 4 X114.5
    Click Me
      Thanks and what exactly is the read? Very newbie I know sorry.
      NEW MYRIDE THREAD
      PARTS 4 SALE
        I met to say tire width not read.
        Click Me
          This is very confusing. For me the width was 205 which would be the measurement from one edge of the surface to another no?
          NEW MYRIDE THREAD
          PARTS 4 SALE
            read stickies.. and all of you question should be answered.. here's a couple..
            http://www.cb7tuner.com/vbb/showthread.php?t=36678
            http://www.cb7tuner.com/vbb/showthread.php?t=60856
              for a tyre 205/40/17
              205 = width of the tyre in mm
              40 = height of sidewall with respect to the width (in percentage), in this case, 40% of the 205mm width makes up height of the sidewall
              17 = wheel diameter in inches
              Click sig to view MR thread
              Links to other rides:
              Honda Accord Euro-R
              Honda Odyssey Absolute
              Honda City I-DSi
              Honda Stream
                Don't buy a 205/40R17 for your Accord, though. It's much shorter than your stock tire diameter and your speedometer will be way off. 205/45R17 is essentially an exact match for the diameter or your stock tire.
                ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                Project Deerslayer
                UPDATE: DEER - 2, CB7 - 0
                '93 EX 5-speed coupe
                Short ram intake
                Tenrai Himoto catback
                Smashed front end
                  Hi. I wasn't. It was just an example of tire size for the explanation. 205/45/17 is pretty much the best tire size for our CBs since there's only a difference of 0.26%. I just learned that today :P
                  NEW MYRIDE THREAD
                  PARTS 4 SALE
                    has anyone successfully gone with wider tires than 205? just curious how big you can go
                      Way off?
                      Tire speed calculator from Discount tire
                      This will give you an Idea of the difference you will see.
                      I run a 205/40R17 and it's pretty damn close to what I run MPH wise.
                      3 CB's gone....
                      1 WK Overland....
                      Still miss the CB though......maybe one day.
                        Originally posted by 91Accord-LX
                        Way off?
                        Can't you just adjust the speedometer to your new wheels? Has anyone done that before?
                        NEW MYRIDE THREAD
                        PARTS 4 SALE
                          oooh i would love to see a meter that can be recalibrated. ;tu:
                          im running 205/50/16 front, 225/45/16 rear
                          Honda Accord Euro-R
                          Honda City I-DSi
                          Honda Stream
                            You in fact seem to be wrong. You are more than 3% off. According to that site, the closest match would be 205/45/17 and is only 0.21% off.
                            im running 205/50/16 front, 2/45/16 rear
                            No need for sarcasm. I'm here to learn, otherwise I wouldn't of started this thread.
                            What's the result of running different tire sizes in the front and the back?
                            Also, what is the exact stock rim and tire size? On some website it says 185/70/14 while on another it's 195/60/15.
                            Confusing.
                            NEW MYRIDE THREAD
                            PARTS 4 SALE
                              Confusing.
                              No sarcasm intende at all. I would really love to get a meter that would recalibrate itself. Seriously
                              im running wider rims at the back, hence the 225/45. but they are very much similar in rolling diameter as the front 205/50
                              Stock rim/tyre sizes depend on trim and market.
                              my car came 165/R14 from the factory. No joke. It says so on the door sill.
                              Honda Accord Euro-R
                              Honda City I-DSi
                              Honda Stream
