Shift Knob Question
    Here ya go dood...Nail's DIY info: http://www.cb7tuner.com/vbb/showthre...t+boot+removal
    i got my shift boot from "K2motor.com"...4 to 5 days to recieve it...no shipping. It's easier than you think.
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
      ummm . . . the shift boot/shift knob attachment clippy thing.
      I really don't know the real official name for it.
      1992 Accord EX 4dr 5spd - SOLD after just over a decade of ownership
      2000 Subaru Legacy GT wagon 5spd
      AHM Platinum Parts Counterperson
        Originally posted by LX_Accordian
        i see, whats that square part called?
        Probably a boot attachment clip. The boot attaches to it with a simple ziptie. Almost any accessory boot can be attached to it. The boot you posted a link to should fit if you remove the round clip that it comes with, but probably not without making your shifter physically shorter. The opening at the top is considerably smaller than the stock boot, so you would have to attach it lower in the boot. This would reduce the height to which it will stretch, so it may not fit your stock shifter unless you either shorten it or perform a bucket drop.
        ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
        Project Deerslayer
        UPDATE: DEER - 2, CB7 - 0
        '93 EX 5-speed coupe
        Short ram intake
        Tenrai Himoto catback
        Smashed front end
          it wasn't that shift boot...i have one similar to that but with red stiching and it is pretty good quality...i haven't tried to fit it but i'm pretty sure it would fit.
          1991 EX Coupe
            so just to clarify, if i wanna change the shift boot, my options are
            cb's, cd's, prelude, and integra shift boots?
            i'm not sure about the oem's, but if you have a sewing machine, it is much cheaper to make your own. take your shift boot off, cut all the stitching so that there is just 4 triangular pieces of vinyl. trace these onto a new piece of vinyl, leather, or suede (dont use cloth, it gets worn out too easily) and cut them out. sew them together like it is inside out so the edges arent seen, then you can backstitch for looks if you want. turn it right side out, sew the metal bottom ring to it, then mount it up. now you have a shift boot that you made how you want; the material, the the color of the material, the color of the stitching, even the size if you decided to modify it.
            hope this helps!
              I have a momo shift knob and boot and they fit perfectly and look great. it has been a couple of years sence I bought them but I belive it was between 35 to 50 dollars give or take . my knob and boot are one peice .
              WE MISS YOU JO(9-04-2008)
                I know a lot of people (including me) who run the ITR/CTR boots. Just look around, you can find them from 25-30$. You can just stretch it over the stock clip, it's a tight fit but you get an oem look/feel with it if that's important to you. The boot really looks pro if you combine it with the CTR shift collar, the little piece that holds the boot up. Then top it off with whatever shift knob you want.
                  damn...so what did u do?
                  that wouldnt happened to be this would it:
                  unvsl. shift bt.
                  This one fits nicely. I got it for my accord and I didn't even have to modify it.
                    thx man, so i could just re-install the boot with a staple gun?
                    My 1992 honda accord LX 5 spd.
                    "Behold! What was once thought to have been
                    buried beneath the sands of time,
                    the ill-fated Haynes Repair Manual has been resurrected
                    from the depths of a watery grave." - LX_Accordian
                      hope this helps!
                      thanks alot man, where's a sewing grandma when u need one? lol.
                        sorry man, whats "ITR/CTR" stand for?
                          i see, i'll b sure 2 look into that. thx man
                            Integra type-R, Civic Type-R
                              thanks man
                                hi,
                                i'm fairly new to tuning in general. i was wondering, are there aftermarket shift knobs made specifically for cb7's or will most aftermarket shift knobs fit?
                                any shitf knob will fit a cb7
