so it all started when i put my new driver side front door on...(had to replace it due to the fact that my window runners were fked)well during the removal of my old door..i cutted all the harness that was behind the fender...all 14ish wires had to be cut to be connected together to the new door which it brung the harness as well as a new mirror..while cutting the wires out,i heard the locking mechanism go off and ofcourse all the doors locked..now i had 2 blown fuses,interior lighting and door lock,but my radio backup and radio antenna fuses are ok.now everything is hooked up correctly,the speakers are wired correctly.i got infinity kappa refrence series speakers and tweeters front and i think the stock pioneers are in the rear,i have a 4 inch touchscreen dual and it works fine..my question is do you guys think i dont have any sound due to a blown speaker?or is there a radio main relay that i probably missed and blew?what do you guys think?btw i love not having any music cuz i can hear what my engine sounds,the revving and all but it gets quite boring after a long day at work not having any music u know?thanks for the help!
audio sound problem...
u never should have cut that harness.... u pull the rubber thats on the fender back and there is a plug right there ur new door should have it. check ur fuses under the hood also along with in the car.Members Ride sold...
depends on the HU sum of them will not play if one speaker is shorted out....Members Ride sold...
i was askin for opinions cuz that happened to my moms car and even tho it is not a honda is actually a mazda protege..the sound wasnt out of the speakers and in fact the rear speakers were blown due to the fact that they were factory stock.now im asking if this could be a possibility since its a honda not a mazda.i was assuming that maybe the other speakers would play but they dont.hmm...ima check my headunit to see if theres a wire that is not connected propertly or maybe a speaker is blown and that could be the problem...
