2ohm speaker with deck?
    this isn't for my Cb7 but for my Delta 88, it has 3.5" speakers in the dash and i've been thinkin of gettn the infinity ref3022 model, they are 2 ohm rated at 25 watts rms and my deck is pushing out 22x4 rms, from what I understand 2 ohm draws more power, will this damage the deck? dnt want an amp for such a small speaker lol, any help appreciated
    I don't think your deck can support 2 ohms for too long.
    YouTube Clicky!!
      ok thanx, the closest amp i found is 60 x 4 (2 ohm) and the speakers only need 25 watts, does anyone know of any amps that put out a little less at 2 ohms?
        2 ohms is a pretty good load. Most car stereo speakers are 4 ohm and home stereo is 8 ohm. Why not just find some 4 ohm speakers instead?
        ~John aka "Heavy Q"~
          That's a good amp to power them.
          YouTube Clicky!!
            ya, you're not going to find any amps with that low of a wattage. because 25 watts @ 2ohms means even less wattage at 4ohms. Which would be useless because the amp would basically be producing at much power as a head unit does. The lowest you'll usually find is 50x4 @ 4ohms, which is often around 65-70 @ 2 ohms.
            So all to say sonik is right, that amp is fine.
