Ok do I need to upgrade if I run 1 jl 8w7 sub with a jl 500/1 amp?
upgrade altornator???
Originally posted by jdm_inspired View PostAlso if you plan on it, you need to upgrade the ground cable connecting to it as well. But yes, no need. Get a capacitor.
-mak
Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
Traded With: cb95spd, chessboxer, sohc em
[ Completed | Pending ]
i just found this out today....the Prelude VTEC alt. the 92-96 model year. Has a higher output than the Accord one: 95 Amps vs 80 Amps. But uses the same exact housing and mounting point. Everything down to the connector is the same as well.
Originally posted by Losiracer2 View Posti just found this out today....the Prelude VTEC alt. the 92-96 model year. Has a higher output than the Accord one: 95 Amps vs 80 Amps. But uses the same exact housing and mounting point. Everything down to the connector is the same as well.
Originally posted by Losiracer2 View PostBut uses the same exact housing and mounting point. Everything down to the connector is the same as well.
BUT to answer charlies quesion no (just like sonikaccord)...you dont need to upgrade your altornator...nor a cap...and yes, caps are usefull even if you dont "upgrade (high output) alternator and sufficient wiring"...
BUT if you have a bad battery or one thats old it might die on you lol had that happend before...so might want to consider replacing/upgrading your batery...gel cells are nice and well worth an investment...
Originally posted by Losiracer2 View Posti just found this out today....the Prelude VTEC alt. the 92-96 model year. Has a higher output than the Accord one: 95 Amps vs 80 Amps. But uses the same exact housing and mounting point. Everything down to the connector is the same as well.Originally posted by H22A91CB7 View Postdoooode!!! if you could do a DIY on how to wire it up we would have something going here
Originally posted by Juan4DCB7 View Postx2
Originally posted by 90accords View PostIt's a direct replacement...... plug and play, no m,odification necessaryLast edited by Losiracer2; 08-02-2009, 10:30 PM.
