hey everybody, well yesterday i tested an amp to make sure it worked before it was sent out, worked, but i noticed that my driver side door speaker isnt working, but my passenger side one was. so i took the door panel off, took out the speaker to see if there was a loose connection, nope, so i grabbed a few other speakers that i knew worked and nothing out of them. So im wondering where i can check to see if there is a loose connection, or if the wire was touched by water and messed up. well thanks ahead of time.
Driver Side Door Speaker
Shit, IDK homie. I would start first with the obvious shit, like checking the connections at the speaker and on the deck. After that I'm assuming it has to be that particular wire, which u would have to follow all through out where ever to see if its corroded somewhere or pinched and shorting. I've personally never run into that problem, without it being a connection. I wish I had some more advice, I'm kinda curious what the hell it could be so keep me posted.
what you could do is disconnect that particular speaker wire(s) and test if it works by connecting it to a 9volt battery and see if it clicks. If it does click your set, no shorts. but if it doesn't you might have to run a new wire from the HU to the speaker.
I feel like its my fault
lol
Rip It Up
Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
i vouch for my Brothas
lol
Rip It Up
if its not a loose wire then i would suggest just throwing speaker wire from radio to the door instead of giving ur self a head ache about it...
Originally posted by deevergotewen yous in da import seen yo, u gotta tipe lyke yous from da streetz cuz it showz dat u git mad rezpect yo. toonerz dun tipe lyke dey gotz a edjakashun cuz dat aint coo.
