hey guy's i just bought a 1400 watt Crunch amp when i got the wiring kit the attendant told me that if the lights on my car go dim i have to buy a CAP if not is going to short the alternator can i just buy a higher amp alt or i need to buy that CAP THANKS for you're help
1400 Watts AMP
The attendant wanted to make more money off you. You don't need a cap. If your lights start to dim, preform the "big 3" and you will be fine. Most of the time you just need to upgrade your grounds under the hood and you will be fine.
(just search "big 3 " on this forum and you will get detailed instructions on how to do it) and 4 gage works fine no need for 0 gage...
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
Originally posted by sugar View Post\i just bought a 1400 watt Crunch amp \Last edited by ChIoVnIdCa; 02-14-2010, 11:08 PM.
Originally posted by True-BlueCB7 View PostDon't bother with caps, period.
x2 on the fusing not many of us have high power amps (1000 rms+) and many get away with the big 3 and a nice batt.
i cant wait to get my cb running again im gonna start a build for everyone to fallow and explain the reasons for doing what i am doing. there are a few others that have builds goin on right now and one im fallowing closing is sonkis build. i think he may have a better highs and mids setup if he can find a great place for his horns.
if u want pics and details on doin a big 3 PM me and i can take some pics.Members Ride sold...
Originally posted by loud92CB7 View Postoh my gawd people are listening on the forum!!!! cheers mates shots on me!
Like he said, the big three and a nice battery should do the trick. If that doesn't help, look on a forum called SMD (Steve Meade Designs) and look around for some tips and such.
Caps=a waste of time.
Start with the Big 3 upgrade (I use 0 gauge monster, you might be able to get away with 4 gauge stuff though, so long as you don't do something like use a wal-mart brand which is the equivalent of about 8 gauge).
Run 4 gauge or better to your amp (you can maybe get away with 8 gauge, but it'll waste some power due to resistance, and if it runs a slightly lower voltage, your amp will heat up. I use 4 gauge on even my 300 watt amp, it's just plain better stuff).
If your lights do start to dim, don't buy a cap. Either upgrade your battery, or add a second one, your choice.
If your lights continue to dim with the upgraded or added battery, that means you're using too much power and adding more batteries or caps will NOT help the problem. You'll have to upgrade your alternator at that point.
Originally posted by preludejim View Postim running 0 guage and a 3,000 watt amp to my 12's and a 300 watt alpine v12 amp to my highs and mids in my 3rd gen lude and my lights dam near turn off when the bass hits hard. the lude is down ,but i'm planning a bit of an upgrade on my eletrical systemMembers Ride sold...
So your overall resistance is 1/2 ohm? If you're pushing 3000 watts at that power when it can't push that at 1/4 ohm it might fry your amp. Or the lights dimming can too (running the lower voltage to your amp means it draws a higher amperage to put out the same power, resulting in more heat, and risking a meltdown of the amp). But I'm assuming you knew how to check the outputs with a DMM and figure out the right gain settings and everything.
