Hey guys , my rear speakers are draining my battery when i plug the wires together. and it leaves me with a dead battery so i left them unplugged. Its not the stock wiring. does any 1 know what i could do to fix this?
Rear speakers draining battery
What made you even think to unplug the rear speakers when your battery was draining? I mean I know that when the battery drains on my car the first thing I think of is to unplug the rear speakers. Oh, and when it runs out of gas I remove the passenger's seat... There's some missing information here.
What made me think it was the speakers was because this car used to be wired for Subs and everything. When i bought it , it didnt come with any of that, just the radio and front speakers. the rear speakers were there but i noticed the wires were cut. so i reconnected the wires not having any idea, and they worked just fine. after that my battery started draining when i left it sitting. so i unhooked it and it didn't drain my battery at all. so im trying to figure out how i can have them hooked up, without having to plug them in and out everytime i shut off my car.
There are better ways to tell him to explain it clearer.Originally posted by Sarthos View PostWhat made you even think to unplug the rear speakers when your battery was draining? I mean I know that when the battery drains on my car the first thing I think of is to unplug the rear speakers. Oh, and when it runs out of gas I remove the passenger's seat... There's some missing information here.
It's obviously a wiring issue, Either a live wire, or a bad ground. You are going to have to trace it unfortunately. In the end it will be worth it. Let me know a little more about your wiring. I can be of some help.
I'm really confused...I'm thinking the rear speakers are 100% unrelated and your battery is junk.
If your speakers are draining power, it requires them to actually see power passed through them. Which should make noise. The only thing I can think of that would do what you're talking about would be if you wired the speakers like directly to your battery...but that wouldn't work. And the stereo DOES turn off right?Last edited by Sarthos; 12-03-2010, 03:18 AM.
You are sort of incorrect in your assertions about the speakers making noise. Speakers use an AC input to generate the proper frequencies. I'm not 100% sure, but I would guess that a straight DC input would just pull the cone to one stationary position.Originally posted by Sarthos View PostI'm really confused...I'm thinking the rear speakers are 100% unrelated and your battery is junk.
If your speakers are draining power, it requires them to actually see power passed through them. Which should make noise. The only thing I can think of that would do what you're talking about would be if you wired the speakers like directly to your battery...but that wouldn't work. And the stereo DOES turn off right?Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Correct. That's exactly what happens.Originally posted by foamypirate View PostYou are sort of incorrect in your assertions about the speakers making noise. Speakers use an AC input to generate the proper frequencies. I'm not 100% sure, but I would guess that a straight DC input would just pull the cone to one stationary position.
It sounds like the speakers are connected to something other than the speaker output of a radio or amp. When you are attaching the wires to the speaker you are completing some circuit through the voice coil.
I wonder if you removed wires from the speaker and connected them together, would you get the same result?
You really need to trace the wires back to the dash to see how they wired and what their function is.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
