my speaker went out and its not blown so wat can be wrong?
my speaker box is out
Amps can come on but it can be faulty and not putting out a signal. Invest in a standard volt meter that reads volts, amps, and ohms.Originally posted by accordboy2011 View PostThe Amp Is Still Comes On So U Think The It Could Be The Radio
Test for power at the remote at the amp, then test for constant.
Then switch to ohms and test the subs positive and negitive at the terminals as Its disconnected. It should be showing 2,4,or 8 ohms. If it has no Connection it wont show anything on your meter and there is your problem. If it does then...
Find any test speaker and hook it up to the amp at lower volume, does it play? If not its either an inputto the amp or the amp itself.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
