what exactly can i use my 1200 watt jl mono amp
MOno Amp?!!???!
What do you mean? Mono only means it sending out all the rms watts through one channel. If you want two speakers bridge them or get a 2 channel but then the rms wats will be divided.
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
I think by bridge he was just meaning to run them together (series or parallel)Originally posted by JonnyD View PostI don't understand the question fully either but mono amps are for subs. And you can't bridge a mono amp because it only has one channel no matter how many speaker output terminals it has.
and you can use the amp for any sub application really. just need to fit the sub application so that it fits into a stable ohm load of the amplifier and is not seriously under/over powered by the amp.
You can use it on any size sub just find one that the rms is comparable to....and the ohms are within what the amp can handle....Originally posted by Melgottaexcoupe View Postwhat exactly can i use my 1200 watt jl mono amp
Depends on your mono amp. You will notice a difference in your highs thoughOriginally posted by sanJ_01 View Postspeaking of monos...i got a no name mono amp and an infinity dual channel thats paired with just my infinity sub, would it make a big difference in sound if i used the dual channel for the front and the mono for the sub, even though they weren't paired for each other?
12volt.com has your best answer bro.Originally posted by sanJ_01 View Postspeaking of monos...i got a no name mono amp and an infinity dual channel thats paired with just my infinity sub, would it make a big difference in sound if i used the dual channel for the front and the mono for the sub, even though they weren't paired for each other?
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
