hey just bought a jenson flip out touchscreen. My problem is that it has a fr,fl,rr,rl rca on the receiver. The diagram shows all four and the sub rca going to the amp but my amp has only two rca plugs. Would i need an adapter or just use the sub rca?
touch screen help
Are u asking this question because the sub rca only has one female end (vs the normal two female ends)? If thats the case the u can purchase a Y connector that has one male end and branches into two female ends. U can then plug the male end into the sub preout and the plug the two female ends to your rca's then to the amp.
Some decks have a singular rca for the sub preout, some have two.
what do you plan on using the amp for? subs or speakers? the fl fr rl rr that you are refering to are just ch outputs witch you would need if using a 4ch amp. since you are using a 2ch amp you willy only be using either the fl/fr or rl/rr ch. so basicly you have two options. if your using your amp for speakers you would hook up rcas from your deck fl and fr to your amp. if your using it for subs you would hook up your rl and rr to your amp. hope that made sense
Why would he do that if he has a dedicated sub preout? He also might not be able to use the subwoofer menu options if he doesn't use the sub preout.Originally posted by s.lownslow.e View Postif your using it for subs you would hook up your rl and rr to your amp. hope that made sense
That connector is like 5 bucks he should be able to get it.Originally posted by SPLCB7 View PostYou can run the rear rca's for your subs till you can get a y female to male connector I have the same deck......
not a good thing to say. keep your eyes on the road sir!Originally posted by roketdemon02 View Postso i can watch movies on the go
agreed. I connected a kenwood deck in co ordinance so my cousin could do the same thing, he payed me to do it. i warned him about it. thats why his car is in the body shop now getting his front end re done.Originally posted by kosheen1 View Postnot a good thing to say. keep your eyes on the road sir!Everyday is one day closer to completing my cb7 <3
