i have my amp set at minimum settings and when the bass hits the amp shuts off. could it be my ground
Amp Problem
Your subs coil might be messed up,slightly damaged then itll be a different impeadence then when it hits it throws the amp into protect mode. check your power connections esp your ground to the car, then check the sub with an ohm meter and its connections. turn the crossover frequency and gain to ½ for both and see if that helps then tweak from there
sounds like you were running wrong impedance...
if you were running bridged at 2ohm on 1 or 2 subs on a bridge that only supports 4 ohms, the amp will drop into protect.
then when you unbridged them you were either running 2 ohms on a single 2 ohm stable channel (1 sub) or you had each channel set at 4 ohms on a 2/4 ohm stable channel (2 subs) the amp will stop dropping out, but you wont be seeing quite the same amount of power.
my shit kept cutting off earlyer today but i figured out my issue. rf t1000.1bd + 3hp + decaf = wires vibrated loose on processorOriginally posted by SPLCB7 View PostCheck your voltige two and your positive connections if voltage drops below 8 volts your amp auto shuts off. I don't really think your amps that strong wattage wise but you never know. Of you have a loose + conection that two will make it shut off.I'd say most likely it's your ground....
Can't go wrong with more settings. That and boss isn't the best brand for amps so I'm shure what you got was a upgrade.Originally posted by CozmoCon View Posti had a boss amp before but i liked the one i got because it had more settings to play with
