I need help for power folding mirrors!
    I bought some power folding mirrors with some heated mirrors as an extra, along with 3 buttons (2 folding mirrors button and 1 heated mirrors), and a harness! So my question is if I can connect the harness with one of the relays that are in the car or am I going to buy the relay too?
    I don't think you're going to be able to use an existing relay, it will need its own.
    -Ian
    '92 EX Coupe (Member's Ride Thread)
    My Blog - Mostly snark about professional motorsports, but I occasionally make it to local and regional events. It's not much now, but I'm working on it.
      You need to read this
      And NO, you won't be able to use the heated mirrors unless you want to compromised the wiring from the PFM. you can only have one at the time.
      JDM Parts for sale
        I'm not sure about the wiring on the heated mirrors, but the installation of JDM power-folding mirrors requires its own relay box. The link that dannyd posted gives the essential wiring diagram for the setup.
        That said, I believe there was one member on this site, possibly xkjnboix, who was able to wire heated AND power-folding mirrors. Do some investigating, you'll get your answer.
        Original-Owner 1991 Honda Accord
        2005 Acura TSX 6MT
        2010 Mazda Miata Grand Touring
          the heated mirrors are going to be connected to the defroster, thanx for the info guys, i guess i have more things to gather to finish the job!
            xkjnboix has done the PFM with Anti Glare film, not heated.
            Good luck doing it, I will not say that it's impossible.. I just didn't see how to do it.
            I already took apart my power folding mirrors and I been studying the idea, there's too much wiring going thru the housing already, and there's no room to run 2 more wires from the heated element. I will take pics tomorrow ans post them since everything its apart.
            JDM Parts for sale
              I been looking around, Can I use the relay of a dc Integra? If I can then I'm set and I will message xkjnboix about it!
                Relay for what??? the heated mirrors or Folding??
                As far as I know you only need a relay for the Power Folding option, the heated elements don't require any relays. I already wired mine for testing and no relay was needed it.
                JDM Parts for sale
                  I wanted to know that if I can use the dc integra relay for the power folding option?
                    Yes, the function its the same, so it should work just fine.
                    JDM Parts for sale
                      Yes you can do this. I just finished building mine. I had lucifer1 help me on the wiring portion as far as where to tie in the heated mirror wires.
                      Here's what I did:
                      I put a 2-pin connector on the mirror lens itself so that the mirror can still be removed in the same fashion it always has. Then I mounted the femal end of the connector inside the housing out of the way of the moving lens. I just used an epoxy to glue it down as far back as I could. It's a bit tedious to get the male connector in there when I'm going to plug it in but I don't anticipate doing this often.
                      The two wires coming out of the female connector I stripped and pinned with pins from spare connectors and inserted them into the factory 8-pin connector.
                      (The following is still in progress)
                      On the corresponding slots on the body side I'll run new wire down through the door and into the body and tie into the back of the underdash fuse box. You want to tie on of the wires into the black/green wire that comes from the rear defogger relay. Again this on the back side of the fusebox where the wire has left that relay on its way to the rear defogger.
                      This way when you turn on the rear defogger your mirrors will be on a relayed circuit and be subject to the same timer as the rear window.
                        i have jdm PFM + HEAT in both my cb7 and ba4
                        you do have to run the heat wires yourself through the housing and folding motor. since my rear defrost never worked since i bought the car i use it as the separate relay + fuse etc for the side mirrors. everything else is regular jdm pfm wiring.
                        the ba4 actually has a special switch which has both heat and fold on it but its very rare and only a handfull members on preludepower have it. and it wont fit the cb7.
                        [COLOR="Magenta"]
                          I looked in your MRT, and didn't see it listed. I guess running the wires thru the folding motor wasn't a piece of cake since everything is so fucking tight there.
                          JDM Parts for sale
                            yeah im still screwed up since the october crash T__T
                            it really depends on what style of mirror you have belt type or non belt type. i believe the belt type was slightly but i dislike the belt type design.
                            [COLOR="Magenta"]
                              Belt??? I never saw a belt in there.
                              JDM Parts for sale
