But what about swapping whole clusters and not the parts inside?
cluster issues
As I described above, 90-91 clusters plugs are different from 92-93 and vice versa. You cannot fit a 92-93 cluster into a 90-91 because the plugs are all different sizes.
Unless you want to cut your plugs of and do some custom wiring, that's about the only way I could see making it work.
Tidbit:
My coupe was built 8/90 in Ohio, equipped with an NS cluster
The parts sedan I have right now was built 11/90 in Japan with a Nippo Denso cluster
Originally posted by crazymikey View PostOnce you disassemble the cluster, all 4 gauges are separate and can be replaced individually.
...What you need to look out for if you're swapping parts from your cluster, is that you will need to find a matching cluster.
... 90-91 clusters are different from 92-93 clusters, as the pig tails and the wire harness plugs (the 3 main green plugs) are different sizes and do not fit.
