Instrument cluster lighting.
    Tonight while I was driving I dimmed my cluster lights. I noticed that there was no light coming from behind my temp gauge. To be honest, I couldn't remember if I've ever seen it lit up.
    Is the temp gauge supposed to have a light behind it.
    There's 2 little bulbs behind the fuel & temp gauges.
    Probably burned out.
      Thank you for the speedy reply. I didn't want to take the dash off to find out it doesn't light up.
        no need to take the dash off. just take the black trim off then there are 4 screws on each side of the cluster and 2 connectors on the bottom. pull the cluster out and take off the connector on the top and you will see 2 or 3 brown twist off lights. they should have a blue rubber cover on them. replace the light that is out and reinstall i have done this way to many times. i can do this in my sleep now lol
        visit vgruk
          Easy enough, I will take care of it next month while I change out the suspension.
          While I replace them, is there a chance I could change the colors of the lights?
          I also would like to light the climate control knobs if there was a way
            I have never tried it but i dont see why not. What colors the bulb is a rubber sleeve. If you can fashion another sleeve im sure it would work
            As for temp knobs i have no idea
            visit vgruk
              Yes. You can get LED bulbs to replace them in any colour. The sleeve thing could work I suppose, just be careful about what you use because those regular bulbs create heat.
              There is a way to light the climate control knobs. Someone on here has done it and explained it step by step in another thread. Search for 'climate control' in the DIY section.
              ^^Photos taken by me ^^
                Found that DIY. I love the way that climate control looks. Thank you.
                  Just a quick addition. Be sure that you remove the negative battery cable. I didn't do that once and I messed up my fuel guage.
