Opinions on Speaker Amplifiers
    I have a Marine Channel Amp that I got somewhere along the line but is it even worth using? I know next to nothing about audio but if it will improve something I might as well install, right? Help clear things up please
    Marine amps and components are waterproofed so they can mounted pretty much anywhere in a boat. Hook it up and test it out. If it works, you should be fine.
      other than Marine amps being a lil more water resistant than basic amps, there would be no sound dfference, Is it a 4channel or a sub amp?
        use it to drive some tweeters. high hats like sonic darts in peoples eardrums.
          amps are most definitely worth the investment. however, I can't speak on the quality of the amp you mentioned. more power to the speakers = louder. also, with an amp you can tune the exact frequencies you want to go to each set of speakers (remove bass from tweeters, only send low end frequencies to subs, etc.) which will help protect your speakers by only sending the frequencies they are meant for to them. you can set eq's with your deck, but amps are generally better.
            I prefer Memphis car audio... its rather expensive, BUT it's WELL worth the price. i have a 75x4 class AB amp. i love it, and its the new style memphis put out.
            Progress thread on my '93 CB7
