I have a set of boston component speakers withthe tweets and the little box it comes with. My question is will you get more bass if planted in the rear deck of our cb's or in the front doors?
Boston component speakers
component speakers are not designed for bass, they are for mids/highs. trying to get even decent bass out of them is just going to accelerate wear and blow them quicker. you will want at least a small subwoofer for bass.
Eye Level Media - Commercial & Automotive Photography: www.EyeLevelSTL.comOriginally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
To get a decent bass response you need the speaker mounted solidly on something that won't vibrate. You also need an enclosure around the speaker. Neither locations provide these neccesities.
You best bet would be the front doors to keep whatever you get bass up front for better sound. You need to make a new speaker baffle, solidify the sheet metal so it won't flex and finally seal the doors as much as possible.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
I see. I take it you did all of this?Originally posted by lucifer1 View PostTo get a decent bass response you need the speaker mounted solidly on something that won't vibrate. You also need an enclosure around the speaker. Neither locations provide these neccesities.
ShiroiKinCB
Partially, wood baffle, 8mm butyl/mastic sound deadening on outside door skin and some memory foam to reduce back waves, buytl dampener and memory foam on inside skin with all holes and wires cover overOriginally posted by ShiroiKinCB View PostI see. I take it you did all of this?
To really reinforce it, I would cut out door and weld in .25" plate for speaker baffle and across inside skin for a stiffener.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
