Has anybody used a universal alternator? Like a power basturds fitzall alternator or any other alternator?
Universal alternator
I have plans for one. I need to get an alternator before I can even put it in really. I'm trying to avoid DC because the price is pretty high and I think singer would give me a lower price to build one. The universal alternator would be a nice choice for now tho.Originally posted by sonikaccord View PostHuntsville! I went to school there. I believe Stoner51 on here isnt too far from there. He has upgraded to a HO alt from DC power and saw a pretty substantial gain in idle output.
I'm assuming you have a high power system?93 4dr ex 5 speed
97 Integra DB7
You will be fine with a alterstart alternator and a second battery. That will still be cheaper than my DC Power and I doubt you will need the idle amperage.
SPLcb7 used a fizzall but it wasn't a drop in. He had to fab a bracket. I had to fab my DC power some too.
I have had two alterstart alternators and they were both fine until I added to the two SPAL HO fans.
steve
No. I just plan of having a big stereo for my enjoyment.Originally posted by sonikaccord View PostPlans as far as how much wattage? Are you going to compete? SPLCB7 is a good reference for that. I'm more of an SQL guy.
Will you be playing full volume at idle?
Around 2.5K all together. Including a 4 channel.Originally posted by SPLCB7 View PostStinger alts arnt too bad. What wattege do you plan to run?
I could probobably make a bracket. It'd save some money for sure. Just how reliable is the alternator? I haven't seen the best reviews for them.Originally posted by Stoner51 View PostYou will be fine with a alterstart alternator and a second battery. That will still be cheaper than my DC Power and I doubt you will need the idle amperage.
steveLast edited by Jarrett; 09-19-2014, 09:09 PM.93 4dr ex 5 speed
97 Integra DB7
It easily handled all my needs until I put in the 2 spal HO fans. 60 amps constant. At idle it wasn't enough. Driving it was fine.
My DC power is rock solid at 14.4 all day long even with the spal fans. But at $500 compared to $200 I am not sure it is worth it.
Have you upgraded your Big 3? If not I would do that before you upgraded the alt not after.
With my DC power alt the charging light on the dash is always on. Not sure why. it wasn't that way in the first hour or two and now It is on all the time. But my hondata s300 reads 14.4-14.8
steve
I haven't done anything yet. Just planning ahead thats all. I got 3 12 Obsidian V3's laying around that I've been dieing to get to use. Haven't even built a box yet. And right now I have my Saz-2000D on 8 ga wire with a pioneer champion series 12. Just for now. I don't even have the gains high enough for it to be loud since I'm using 8ga wire.93 4dr ex 5 speed
97 Integra DB7
A good stinger alt is a great choice. Also The use of an optima deep cycle blue top helps and keeps everything flowing right and helps prevent the head light dim and bright during high bass use. Kenetic batteries can be used also with the stinger alt and an optima blue top.To jdm or not jdm that is the question
Since when did Stinger makes alternators?Originally posted by greenhornet614 View PostA good stinger alt is a great choice. Also The use of an optima deep cycle blue top helps and keeps everything flowing right and helps prevent the head light dim and bright during high bass use. Kenetic batteries can be used also with the stinger alt and an optima blue top.93 4dr ex 5 speed
97 Integra DB7
but 220-250 would be ideal.
