buildin a box wat kinda wood should i use an was kinda speakers i want idk
custom box
morning wood works wonders. Go to Home depot, or lowes and ask the person in the lumber section, they will be able to guide you the rest of the wayOriginally posted by hotboxnaccordbuildin a box wat kinda wood should i use an was kinda speakers i want idk
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Originally posted by CustomLowzmorning wood works wonders. Go to Home depot, or lowes and ask the person in the lumber section, they will be able to guide you the rest of the way
i couldn't of said it better myself. that stuff works wonders, i used it to build my box, and it's' got nothing but
's from me.
If you are concerned about weight issues, you "could" use 5/8 MDF (medium density fiberboard)......I've used this in the past. the only thing is you will need to pre-drill ALL of your screw holes or you WILL split the wood. Also make sure you run a bead of silicone or something similar on the inside of every joint, whether ported or sealed, so you dont get any stray air hissing out of a joint when the sub hits.
